+1 866-287-2558
Mon-Fri 9:00-18:00 EDT
Become a Distribution Partner
Restaurants
1/2
Go To
position
Set Descending Direction
  1. Lepro LED Strip Lights, 40Ft RGB LED Strips, 5050 SMD LED Color Changing Strip Light with 44 Keys Remote Controller and 24V Power Supply, LED Lights for Bedroom, Home, TV Backlight
    40ft RGB LED Strip Lights, 5050 SMD Color Changing LED Tape Light with 44 Keys Remote Controller for Bedroom, Home, TV Backlight
    Light Color: RGBProtection Rating: IP20Package Quantity: Pack of 1 UnitPower Consumption (W): 24Length (ft): 40 Safety Rating: FCC
    FREE 1-5 Days Shipping Over $39
    $19.99
  2. 50W 2x4 panel light
    2 Pack 2x4 50W Flat LED Panel Lights, 6500 Lumens, 5000K Daylight White Dimmable Flat Panel Lights for Offices, Schools, Hospitals and More Commercial Lighting
    2 Pack 2x4 50W Flat LED Panel Lights, 6500 Lumens, 5000K Daylight White Dimmable Flat Panel Lights for Offices, Schools, Hospitals and More Commercial Lighting 4 5 5 1
    Light Color: Daylight WhiteBrightness (lm): 6500Protection Rating: IP20Package Quantity: Pack of 2 UnitsColor Temperature (K): 5000Power Consumption (W): 50 Safety Rating: ETL Warranty: 5 Years Input Voltage: 120-277V AC
    $209.00
    ($104.50 / unit)
  3. 65.6ft rgb led strip lights
    65.6ft RGB LED Strip Lights with Remote Controller, Ultra-Long 5050 Color Changing LED Tape Light for Living Room, Bedroom, Kitchen or Christmas Tree
    65.6ft RGB LED Strip Lights with Remote Controller, Ultra-Long 5050 Color Changing LED Tape Light for Living Room, Bedroom, Kitchen or Christmas Tree 16 5 5 1
    Light Color: RGBPackage Quantity: Pack of 1 UnitPower Consumption (W): 24Length (ft): 65 Safety Rating: FCC Input Voltage: 120V AC
    $29.99
  4. LE BR30 E26 LED Light Bulbs, 10.5W 850lm, Dimmable, Equivalent to 65 Watt Incandescent, 5000K, Daylight White, 110° Wide Beam Angle, for Kitchens, Living Rooms, Bedrooms and More, Pack of 8
    LE BR30 E26 LED Light Bulbs, 10.5W 850lm, Dimmable, Equivalent to 65 Watt Incandescent, 5000K, Daylight White, 110° Wide Beam Angle, for Kitchens, Living Rooms, Bedrooms and More, Pack of 8 7 4.9 5 1
    Light Color: Daylight WhiteBrightness (lm): 850Base Type: E26Package Quantity: Pack of 8 UnitsColor Temperature (K): 5000Power Consumption (W): 10.5 Warranty: 3 Years
    $29.99
    ($3.75 / unit)
  5. LE BR30 E26 LED Flood Light Bulbs, 10.5W 850 Lumens, Dimmable, 65 Watt Incandescent Equivalent, 2700K Warm White, 110° Wide Beam Angle, for Kitchens, Living Rooms, Bedrooms and More, Pack of 8
    LE BR30 E26 LED Flood Light Bulbs, 10.5W 850 Lumens, Dimmable, 65 Watt Incandescent Equivalent, 2700K Warm White, 110° Wide Beam Angle, for Kitchens, Living Rooms, Bedrooms and More, Pack of 8 7 4.6 5 1
    Light Color: Warm WhiteBrightness (lm): 850Base Type: E26Package Quantity: Pack of 8 UnitsColor Temperature (K): 2700Power Consumption (W): 10.5 Warranty: 3 Years
    $29.99
    ($3.75 / unit)
  6. BR30 E26 Warm White Bluetooth Bulbs, dimmable,Various Modes
    LE BR30 E26 Smart LED Light Bulb, Bluetooth, RGBW, Dimmable, 10W 700lm, 3000K Warm White, Multi-Color Changing with Remote Control, Compatible with iPhone, Android
    LE BR30 E26 Smart LED Light Bulb, Bluetooth, RGBW, Dimmable, 10W 700lm, 3000K Warm White, Multi-Color Changing with Remote Control, Compatible with iPhone, Android 9 4.6 5 1
    Light Color: Warm WhiteBrightness (lm): 700Base Type: E26Package Quantity: Pack of 1 UnitColor Temperature (K): 3000Power Consumption (W): 7
    $7.99
  7. Lepro GU10 Smart Light Bulbs, RGB Color Changing LED Bulb, Compatible with Alexa & Google Assistant, Dimmable with App, 50W Equivalent Track Light Bulb, No Hub Required, 2.4G WiFi Only, Pack of 4
    Lepro GU10 Smart Light Bulbs, RGB Color Changing LED Bulb, Compatible with Alexa & Google Assistant, Dimmable with App, 50W Equivalent Track Light Bulb, No Hub Required, 2.4G WiFi Only, Pack of 4 2 5 5 1
    Light Color: RGBWBrightness (lm): 385Base Type: GU10Protection Rating: IP20Package Quantity: Pack of 4 UnitsColor Temperature (K): 2700-6500KPower Consumption (W): 4.5 Safety Rating: FCC Input Voltage: 120V AC
    $28.99
    ($7.25 / unit)
    Out of stock
  8. LE 82ft LED Strip Lights, 120 Volt, 120W 1500 SMD 3528 LEDs, Waterproof, Flexible, Warm White, ETL Listed, Indoor Outdoor LED Rope Light for Kitchen, Ceiling, Patio, Under Cabinet Lighting and More
    82ft LED Strip Lights, 120V 110V, 120W 1500 SMD 3528 LEDs, Waterproof, Flexible, Warm White, ETL Listed
    82ft LED Strip Lights, 120V 110V, 120W 1500 SMD 3528 LEDs, Waterproof, Flexible, Warm White, ETL Listed 3 4.4 5 1
    Light Color: Warm WhiteProtection Rating: IP65Waterproof: YesPackage Quantity: Pack of 1 UnitColor Temperature (K): 3000KPower Consumption (W): 120 Safety Rating: ETL Input Voltage: 120V AC
    $39.90
    Out of stock
  9. LE 65ft LED Strip Lights, 120 Volt, 95W 1200 SMD 3528 LEDs, Waterproof, Daylight White, ETL Listed, Flexible Indoor Outdoor LED Rope Light for Kitchen, Ceiling, Patio, Under Cabinet Lighting and More
    65ft LED Strip Lights, 120V 110V, Daylight White, 95W 1200 SMD 3528 LEDs, Waterproof
    65ft LED Strip Lights, 120V 110V, Daylight White, 95W 1200 SMD 3528 LEDs, Waterproof 4 4.5 5 1
    Light Color: Daylight WhiteProtection Rating: IP65Waterproof: YesPackage Quantity: Pack of 1 UnitColor Temperature (K): 6000KPower Consumption (W): 95 Safety Rating: ETL Input Voltage: 120V AC
    $34.66
    Out of stock
  10. LE 65ft LED Strip Lights, 120 Volt, 150W 1200 SMD 5050 LEDs, Waterproof, Flexible, Warm White, ETL Listed, Indoor Outdoor LED Rope Light for Kitchen, Ceiling, Patio, Under Cabinet Lighting and More
    65ft LED Strip Lights, 120V 110V, 150W 1200 SMD 5050 LEDs, Waterproof, Flexible, Warm White
    65ft LED Strip Lights, 120V 110V, 150W 1200 SMD 5050 LEDs, Waterproof, Flexible, Warm White 12 4.9 5 1
    Light Color: Warm White-Daylight WhiteProtection Rating: IP65Waterproof: YesPackage Quantity: Pack of 1 UnitColor Temperature (K): 3000KPower Consumption (W): 150 Safety Rating: ETL Input Voltage: 120V AC
    $41.61
    Out of stock
1/2
Go To
position
