Best LED Shop Lights for Garages, Workshops and Warehouses – 2024 Reviews
As LED lights have become more common, LED shop lighting has found increasingly broad applications in large retail spaces, warehouses, garages, factory buildings, etc. Today we are going to look at 5 of the most popular models of LED shop lights. You can compare the features of each model and purchase the one that most suits your requirements.
Top 5 LED Shop Lights
#1. Lepro 4ft LED Shop Lights
  • High efficiency: This 42W LED shop light is equivalent to a 100W fluorescent light, saving 60% on electricity costs. It has a brightness of 4200 lumens or 100lm/W.
  • Max connections: 8 units. A maximum of 8 units can be connected together, saving time and cost to install.
  • Safety certified. This model is FCC and ETL certified, guaranteeing product safety.
  • Light Color & Color Temperature: This 5000K daylight white LED shop light can provide clear, daylight-level illumination, highly suitable for use even above workbenches where precision operations need to be carried out.
  • 5-year warranty: The product carries a 5-year warranty. Should any damage to the product occur during shipping or if there is any problem using the product, it will be replaced free of charge. LED lights generally have a long lifetime and do not require frequent replacement.
#2. Hyperikon 4 Foot LED Shop Light
  • Energy Saving: The 35W Hyperikon LED Shop Light is equivalent to a 100W fluorescent light, saving 65% on electricity costs. It has a brightness of 3900 lumens or 112lm/W.
  • Price: $119.95 for 4 units, equivalent to $29.99/unit. DLC 4.2 certified. A maximum rebate of $50 can be obtained against a purchase.
  • Easy installation: Besides the light itself, all necessary accessories are included, such as wall plugs and screws, and a mounting stud, making this product easy to install.
  • Long lifespan: Has a lifetime of over 45,000 hours. It also comes with a 5-year warranty and is safety certified.
#3. Hykolity 4FT LED Shop Light
  • High efficiency. The Hykolity 42W LED Shop Light produces 4200 lumens of light. It has a near daylight color temperature of 5000K and saves as much as 70% power compared to ordinary fluorescent lights. Costs $99.99 for 4 units, equivalent to $24.99/unit.
  • Easy installation: Some installation accessories are provided with the purchase. You can hang the light from the ceiling using a chain or install it with screws.
  • Linkable: A maximum of 4 lamps can be connected together, suitable for warehouse lighting, and lighting in other places like factories, workspaces, garages, etc.
  • High Quality. ETL certified for safety. Has a lifetime of over 50,000 hours and comes with a 5-year warranty, so there is no need to worry about problems in use.
#4. Barrina LED Shop Light
  • Super bright: A 20W Barrina LED Shop Light produces 2200 lumens of light, or over 110lm/W, with a color temperature of 6500K.
  • Price: $40.85 for 6 units, equivalent to $6.80/unit. This is a low-cost model that lacks the professional certification of other brands. However, it has a lifetime of over 50,000 hours and carries a 3-year unconditional return warranty.
  • Energy-saving: A 20W Barrina LED Shop Light is equivalent to a 75W fluorescent light, saving 65% on electricity costs.
  • Linkable: The package includes a 20-inch long connector cable and connecting box, enabling 8 lights to be connected together, and making installation easy.
#5. OOOLED 4ft LED Shop Light
  • Energy-saving: The 48W OOOLED LED Shop Light produces 4800 lumens of light, while saving 65% in electricity costs. It has a color temperature of 5000K, producing clear, daylight-level illumination for your factory, warehouse, or garage.
  • 5-year warranty: The light has a service life of 50,000 hours and can be returned and exchanged free of charge within 5 years of purchase.
  • Price: $42.99. It is a bit more expensive than other brands’ products but produces more powerful light.
  • Suitable Locations: This LED shop light is suitable for use in a very wide range of locations. It is commonly used in supermarkets, offices, workbenches, basements, and garages.
Q:  Why choose LED shop light?
  1. They are safe to use. LED lights give off little heat, do not buzz or flicker, nor contain any harmful chemicals. They are completely safe and environmentally friendly.
  2. Compared with other types of lamps, LED shop lights have a longer lifetime and greater efficiency. Although they are slightly more expensive to buy, they do not need to be frequently replaced and can save significantly on electricity costs.
Q:  How to choose LED shop light?
  1. Parameters: Check your light’s illuminance, brightness, color temperature, and other parameters. Because different environments have different lighting requirements, you should choose the most suitable light for the space. If the room needs to be better lit, try to avoid lights with too low a color temperature. An LED shop light with a color temperature of 5000K or above can better meet your needs.
  2. Safety: Check that the light has safety certification. To ensure safety, try to choose safety-certified products. You can also check the light’s lifetime and the length of its repair warranty to ensure a better experience with the product.
  3. Price: Budget is a crucial factor when purchasing lighting. Try to carry out as many comparisons as possible and choose the model with the best price-performance ratio.
Q:  Can LED shop lights be linked together?
Yes. The number of units that can be linked up depends on the brand. For example, up to 8 Lepro LED shop lights can be linked together.
Q:  How do I calculate how many LED shop lights are needed?
First, you need to clarify your lighting requirements. Different spaces require different luminosities. Second, it depends on the intensity of light produced by the chosen lighting when installed at different heights in the space. Generally speaking, you can make a precise calculation using a specialist lighting app such as DIALux or AGI32. After importing the IES file for your lighting into the app and inputting the relevant data for the room, the software can then help you calculate the number of lights required, and also conveniently demonstrate the effect of the lighting on the room.
