LED Light Bulbs
1/8
Go To
position
Set Descending Direction
  1. Lepro GU10 Smart LED Light Bulbs, Compatible with Alexa & Google Assistant, Dimmable with App, 50W Equivalent, Tunable White Track Light Bulb, No Hub Required, 2.4G WiFi Only, Pack of 4
    Lepro GU10 Smart LED Light Bulbs, Compatible with Alexa & Google Assistant, Dimmable with App, 50W Equivalent, Tunable White Track Light Bulb, No Hub Required, 2.4G WiFi Only, Pack of 4 2 5 5 1
    Light Color: CCTBrightness (lm): 385Base Type: GU10Package Quantity: Pack of 4 UnitsColor Temperature (K): 2700-6500Power Consumption (W): 4.5 Safety Rating: FCC Input Voltage: 120V AC
    FREE 1-5 Days Shipping Over $39
    $26.99
    ($6.75 / unit)
  2. Lepro GU10 Smart LED Light Bulbs, Compatible with Alexa & Google Assistant, Dimmable with App, 50W Equivalent, Tunable White Track Light Bulb, No Hub Required, 2.4G WiFi Only, Pack of 2
    Lepro GU10 Smart LED Light Bulbs, Compatible with Alexa & Google Assistant, Dimmable with App, 50W Equivalent, Tunable White Track Light Bulb, No Hub Required, 2.4G WiFi Only, Pack of 2 2 5 5 1
    Light Color: CCTBrightness (lm): 385Base Type: GU10Package Quantity: Pack of 2 UnitsColor Temperature (K): 2700-6500Power Consumption (W): 4.5 Safety Rating: FCC Input Voltage: 120V AC
    $16.99
    ($8.50 / unit)
  3. Lepro GU10 Smart Light Bulbs, RGB Color Changing LED Bulb, Compatible with Alexa & Google Assistant, Dimmable with App, 50W Equivalent Track Light Bulb, No Hub Required, 2.4G WiFi Only, Pack of 4
    Lepro GU10 Smart Light Bulbs, RGB Color Changing LED Bulb, Compatible with Alexa & Google Assistant, Dimmable with App, 50W Equivalent Track Light Bulb, No Hub Required, 2.4G WiFi Only, Pack of 4 2 5 5 1
    Light Color: RGBWBrightness (lm): 385Base Type: GU10Protection Rating: IP20Package Quantity: Pack of 4 UnitsColor Temperature (K): 2700-6500KPower Consumption (W): 4.5 Safety Rating: FCC Input Voltage: 120V AC
    $28.99
    ($7.25 / unit)
  4. LE LED Light Bulbs 60 Watt Equivalent, 8.5W Soft Warm White 2700K Non-Dimmable, A19 E26 Standard Medium Base, 11000 Hour Lifetime, Pack of 6
    LE LED Light Bulbs 60 Watt Equivalent, 8.5W Soft Warm White 2700K Non-Dimmable, A19 E26 Standard Medium Base, 11000 Hour Lifetime, Pack of 6 2 5 5 1
    Light Color: Warm WhiteBrightness (lm): 720Base Type: E26Protection Rating: IP20Package Quantity: Pack of 6 UnitsColor Temperature (K): 2700Power Consumption (W): 8.5 Safety Rating: UL
    $13.99
    ($2.33 / unit)
  5. LE LED Light Bulbs 60 Watt Equivalent, 8.5W Daylight White 5000K Non-Dimmable, A19 E26 Standard Medium Base, 11000 Hour Lifetime, Pack of 6
    LE LED Light Bulbs 60 Watt Equivalent, 8.5W Daylight White 5000K Non-Dimmable, A19 E26 Standard Medium Base, 11000 Hour Lifetime, Pack of 6 2 5 5 1
    Light Color: Daylight WhiteBrightness (lm): 720Base Type: E26Protection Rating: IP20Package Quantity: Pack of 6 UnitsColor Temperature (K): 5000Power Consumption (W): 8.5 Safety Rating: UL
    $13.99
    ($2.33 / unit)
  6. LE Recessed Light Bulbs, BR30 LED Flood Light Bulbs Indoor, Dimmable, 3000K Soft White, 65W Equivalent, E26 Medium Base, Bulged Light Bulbs for Cans, Pack of 12
    LE Recessed Light Bulbs, BR30 LED Flood Light Bulbs Indoor, Dimmable, 3000K Soft White, 65W Equivalent, E26 Medium Base, Bulged Light Bulbs for Cans, Pack of 12 2 5 5 1
    Light Color: Warm WhiteBrightness (lm): 650Base Type: E26Protection Rating: IP20Package Quantity: Pack of 12 UnitsColor Temperature (K): 3000Power Consumption (W): 9 Safety Rating: UL
    $38.99
    ($3.25 / unit)
  7. LE BR30 E26 Light Bulbs, Dimmable LED Bulb, 9 Watts 65W Equivalent, 3000K Soft White, Indoor Flood Light for Recessed Cans, UL & FCC Listed, Pack of 6
    LE BR30 E26 Light Bulbs, Dimmable LED Bulb, 9 Watts 65W Equivalent, 3000K Soft White, Indoor Flood Light for Recessed Cans, UL & FCC Listed, Pack of 6 2 5 5 1
    Light Color: Warm WhiteBrightness (lm): 650Base Type: E26Protection Rating: IP20Package Quantity: Pack of 6 UnitsColor Temperature (K): 3000Power Consumption (W): 9 Safety Rating: UL
    $23.99
    ($4.00 / unit)
  8. LE RGB Color Changing Light Bulbs with Remote, Dimmable LED Light Bulb, E26 Screw Base, 40 Watt Equivalent Soft Warm White, 16 Color Choices for Home Decor, Bedroom, Stage, Party and More, Pack of 4
    LE RGB Color Changing Light Bulbs with Remote, Dimmable LED Light Bulb, E26 Screw Base, 40 Watt Equivalent Soft Warm White, 16 Color Choices for Home Decor, Bedroom, Stage, Party and More, Pack of 4 2 5 5 1
    Light Color: RGBWBrightness (lm): 470Base Type: E26Protection Rating: IP20Package Quantity: Pack of 4 UnitsColor Temperature (K): 2700Power Consumption (W): 6 Safety Rating: UL
    $21.99
    ($5.50 / unit)
  9. Lepro E12 Chandelier Light Bulbs, Filament LED Candle Bulbs, Dimmable 5W 500LM, 60W Equivalent, 2700K Warm White, Ceiling Fan Bulb Candelabra Bulbs, Pack of 6
    Lepro E12 Chandelier Light Bulbs, Filament LED Candle Bulbs, Dimmable 5W 500LM, 60W Equivalent, 2700K Warm White, Ceiling Fan Bulb Candelabra Bulbs, Pack of 6 3 5 5 1
    Light Color: Warm WhiteBrightness (lm): 500Base Type: E12 CandelabraProtection Rating: IP20Package Quantity: Pack of 6 UnitsColor Temperature (K): 2700Power Consumption (W): 5 Safety Rating: FCC
    $16.99
    ($2.83 / unit)
  10. Lepro LED Edison Bulbs, ST64 Vintage Filament Bulb, Dimmable 7.5W 800LM, 60W Equivalent, 2700K Warm White, Classic Clear Glass, E26 Screw Base, Pack of 4
    Lepro LED Edison Bulbs, ST64 Vintage Filament Bulb, Dimmable 7.5W 800LM, 60W Equivalent, 2700K Warm White, Classic Clear Glass, E26 Screw Base, Pack of 4 3 5 5 1
    Light Color: Warm WhiteBrightness (lm): 800Base Type: E26Protection Rating: IP20Package Quantity: Pack of 4 UnitsColor Temperature (K): 2700Power Consumption (W): 7.5 Safety Rating: FCC
    $16.99
    ($4.25 / unit)
1/8
Go To
position
