The Top 5 Alexa Smart Bulbs for 2024
There are a wide variety of smart bulbs on the market, but Alexa light bulbs give you even more control over your lighting because they work with Amazon's speech assistant and Echo devices.
The Lepro Alexa smart bulb GU10 is the greatest Alexa light bulb, according to rigorous testing, due to its attractive colors, simple setup, and intuitive operation.
The Geeni Prisma Smart Bulb provides several smart Alexa lighting capabilities on a budget for something less pricey.
There are, however, several more excellent choices that we've tried, with various features and adaptability so you may choose the ideal match for your house.
Best 5 Alexa Compatible Smart Lights
GU10 Lepro Alexa Smart Bulb
With the free "Smart Life" app, you can simply manage lights wherever you are at any time with the Lepro Alexa smart bulb GU10. Just 2.4 GHz Wi-Fi is required; no hub is needed. Also, it works with Google Home and Alexa, including Echo, Echo Dot, and more, enabling hands-free voice control of the lights.
16 million colors are available for you to pick from, or you may choose brightness-adjustable 2700â6500 kelvin warm to cold white light to set the ideal atmosphere. Your bulbs may be set up with timers and wake-up functions to turn on or off automatically at a predetermined time. The slow increase in brightness mimics the sunrise effect and helps you ease into the day.
To get started with these GU10 LED bulbs, you need to turn on Bluetooth on your smartphone and connect them to 2.4GHz WiFi using the accompanying software; No hub or gateway is necessary. This LED GU10 bulb uses only 4.5 watts of power, compared to the 50 watts required by traditional GU10 halogen bulbs. Also, you'll save money in the long run because you won't have to replace the bulbs as often (up to 15,000 hours).
White and Color Ambiance Starting Set from Philips (3rd Gen)
The finest smart lights for Alexa are always made by Philips Hue. The bulbs are some of the most convenient and brightest ones we've tried. You may modify the bulb's 16 million hues and tunable whites, change the brightness, and activate certain lighting settings by speaking to your Echo speaker or using the Alexa app.
The Hue light bulbs do need a hub in order to function, unlike some other smart lights, which is their main drawback. Although the Hue lights require additional hardware, especially if you choose the Starting Kit that includes the Hue bridge, it's a minor price to pay for the performance and dependability they provide.
LED Smart Bulb Geeni Prisma
For novices, the Alexa-compatible Geeni Prisma Plus LED smart light is a fantastic low-cost option. After Alexa and your device are connected, you may give voice commands like "Alexa, set the bedroom light to cool white" or "Alexa, lower the bedroom light to 25%." The Geeni app, which provides two-factor verification to help keep your account safe, also lets you manage the lights.
Preset lighting scenarios including rainbow, cocktail, night, reading, and rave are available with the bulb. Also, you may design your own sceneries and schedule the lighting. Geeni's Prisma Smart Bulb is the one you want if you're looking for a value-packed smart bulb that works with Alexa.
Kasa Smart Bulb 125
Kasa's Multicolor Smart Light Bulb is comparable to the other top selections in our roundup, with 16 million color options ranging from warm to cold whites. You may control your Alexa-enabled light bulb by just speaking to it, such as, "Alexa, change the kitchen light to cool white," or "Alexa, dim the downstairs to 60 percent."
Moreover, it provides remote control with the user-friendly Kasa app. Kasa smart bulbs also include an away mode that may randomly switch your lights on and off to make it look as though you are home even when you are not.
The Kasa app's energy use tracking feature is another excellent feature of Kasa bulbs that most other smart lights lack.
Cync Full Color Direct Connect Smart Bulb
Cync's latest generation of bulbs eliminates the requirement for a hub, making them a great option for anybody who wants to put up a few lights that can be controlled by an app with no effort. You may use your voice to adjust the brightness and color of these LED smart bulbs with the use of Amazon's Alexa.
If you prefer to keep all of your bulbs white, you can do that as well, and then use the app to adjust the warmth to match your current disposition. Unlike the other Alexa-enabled bulbs in our buying guide, these do not come with any preprogrammed lighting settings.
In conclusion, the top five Alexa Smart Light Bulbs for 2024 are an exciting way to bring technological convenience and style into your home. Each of these lights is energy efficient, voice-controlled, and aesthetically pleasing, creating a unique ambiance in your home that is both beautiful and functional. With their advanced features, itâs no wonder that the demand for these smart lights has risen significantly this year! Now's the time to explore the future of light and find the perfect fit for your lifestyle.
