The Best Bathroom Ceiling Lights in 2024
In addition to being dark and gloomy, a dark bathroom can make it more difficult to complete your morning ritual. Making the bathroom more cheerful may really make a difference. According to studies, being exposed to strong light in the morning might really increase your energy and attention for the entire day.
This article will provide guide to choose best bathroom ceiling lights for illuminating those dim restrooms, which will make getting ready in the morning a delight.
Best Bathroom Ceiling Lights Overview
- Best Flush Mount: Lepro LED Bathroom Ceiling Light
- Best Pendant: Ding Lighting 3 Way Round Light
- Best Light for Makeup: ECOBRT Bathroom Wall Lights
- Best Bathroom Downlights - National Lighting Bathroom Spotlights
- Best Strip Lights - Lepro 5M Waterproof LED Strip Light
By far, Lepro's IP54 waterproof ceiling lamp is the most widely used lighting for restroom use. It is the ideal choice for the majority of bathrooms since it is totally protected against moisture and water splashes.
This brand provides 15-watt and 24-watt light sources, producing 1,250 and 2,500 Lumens, respectively. Although the brighter and more expensive choice is preferable, it comes at a cost.
To summarize, the Lepro Ceiling Light is the perfect bathroom light, providing high light output while being entirely splashproof. If your budget permits, the 24-watt alternative checks all the boxes and will not let you down. The company also has a "smart" option that can be operated via their smartphone application, Amazon Alexa, or Google Assistant device.
With an IP44 rating, the well-known Ding Lighting pendant is a fantastic choice to take into consideration. It is made of sturdy electroplated stainless steel that resists oxidation, and for your peace of mind, it comes with a 2-year warranty. The lights may be adjusted vertically within 90 degrees and can be rotated 320 degrees to best suit your needs.
The Ding Lighting Pendant is a terrific option all around since it has a great appearance, generates amazing light, and is quite affordable. If the provided bulbs fall short of your expectations, the bayonet-fitted GU10 bulbs may also be readily changed.
A fundamental component of effective bathroom lighting design is task lighting, which simplifies daily tasks like applying cosmetics, doing a little grooming, or viewing those hard-to-reach areas when cleaning your teeth.
This clever small wall lamp, which is 60 cm long and generates a wonderfully clean white light, is perfect for placing over your bathroom mirror.
While it can be hooked into your bathroom lighting circuit and works through a wall switch, its IP certification makes it suitable over the sink.
Best Downlights - National Lighting Bathroom Spotlights
Bathroom downlights should be stylish, IP65-rated, fire-rated, and simple to install.
These stylish chrome bathroom downlights, which are offered in packs of four, six, or ten, may be adjusted on a dimmer switch to transform them from bright and effective to soft and inviting. They are ideal for Zone 0, which is above shower stalls and bathtubs, thanks to their IP65 rating.
They also have a lengthy lifespan, 25,000 hours to be exact, which means you won't have to teeter on a stepladder to change them for quite some time.
Best Strip Lights - Lepro Waterproof LED Strip Light
Ideal for emphasizing certain features and architectural aspects in the bathroom and for setting your own mood lighting.
It's simple to adapt these waterproof LED strip lights to fit your lighting design because they are delivered in 3m lengths with cutting marks per three LEDs. They are easy to install anyplace thanks to their self-adhesive backing, such as around the bath's base, behind a mirror, within a ceiling recessed area, or behind shelves, for instance.
Please be advised that a power adaptor is necessary and must be purchased separately. To guarantee optimal adherence, you should also be careful to only apply them to clean, dry surfaces.
IP Ratings for Bathroom Lights
You should be familiar with IP Ratings prior to starting your search for the finest bathroom lights.
Bathroom Zones should be considered when choosing bathroom lights.
Zone 0 The area within the bathtub or shower itself is known as Zone 0. Low voltage light fixtures (maximum 12 volts) with an IP67 rating or above are required for usage in this area (total immersion proof.)
Zone 1 is the area up to 2.25 meters above the bath or shower and the floor. Although an IP65 rating is often utilized as the majority of shower lights are, an IP45 rating is required here.
Zone 2 extends 2.25m above the floor and 0.6m beyond the bath's edge. In this zone, IP44 is a minimum requirement. It makes sense to consider Zone 2 to be the region around the basin and within a 60-cm radius of the taps.
Somewhere outside of Zones 0, 1, and 2 and where a water jet will not be used.
Which Kind of Bathroom Lighting is Best?
Your decision for bathroom lighting should take into account a number of things, such as:
- What zone of the bathroom are you placing the lights in?
- How big your bathroom is
- Spending limit
- Who will install the lighting?
- Your goal for the whole bathroom design
It is difficult to beat a variety of downlighters as a source of general lightings, such as Lepro bathroom LED ceiling light, and Shower/Bathroom IP65. You can place them precisely where you want to ensure good dispersion of lighting, they are subtly designed, and they have an IP Rating that is suitable for Zone 1.
The Brushed Gold Ripon Bathroom Wall Light is available at Dunelm. and is ideal for adding character and warmth to the space if you're looking for a warm, comforting light, though.
