How to Get the Best Bedroom LED Strip Lights Ideas
Why do we choose LED strip lights for the bedroom?
According to the survey, the most important reason people want to decorate the bedroom with LED strip lights is that they can help create a relaxing, warm, and romantic space. Bedroom lighting, in addition to providing a soft light source that allows people to fall asleep peacefully, also helps to relieve the fatigue caused by an intense working and personal life, to create a relaxing home environment. In this situation LED strip lights can be a good choice.
If you also have a love for modern design, then the best place to start is with LED strip light bedroom ideas. The perfect bedroom lighting helps your decor reflect your personal style, but it can also be a very practical solution for any budget. Not only is it more affordable than ever before, but it is also a more functional alternative to standard bulbs.
Here are some bedroom LED strip light ideas, I hope they can help make your bedroom much more comfortable.
Part 1. Best 5 LED Strip Lights Bedroom Ideas
Part 2. Check the Key Features of Bedroom LED Strip Lights
Part 3. Get the Best Lepro LED Strip Lights for Bedroom
#1. Behind the Bedside Background Wall
There are many ways to approach LED strip lights. The first idea I suggest is to have them behind the headboard on the wall. Hidden in the headboard, the refracted light makes the top of the bed more three-dimensional and gives the bedroom a warm and romantic atmosphere.
#2. On the Bottom of the Bed
Put a circle of LED light strips on the bottom of the bed, without turning on the main light at night, the light can promote sleep, and even if youâre lying on the bed and playing with your mobile phone, it will also reduce eye irritation. If we need to get up at night, the light can also illuminate, but it will not particularly glare in the eyes to affect your sleep. LED strip lights under the bed can also help create a warm and romantic atmosphere, which is more conducive to a coupleâs relationship.
#3. In the Ceiling
Embedding LED strip lights in the ceiling is also a very common and great idea. Ceiling lights can be hidden so that the light source indirectly illuminates the ceiling through reflection, breaking a depressing looking space caused by the dim ceiling, the combination of light and dark can enhance the layering of the bedroom.
#4. Behind the TV
Do you watch TV in bed? If so, you can put LED strip lights behind the TV, so that when you watch TV at night, there is enough light so as not to hurt your eyes. Pretty enjoyable, right?
#5. Around the Furniture
Aside from the 4 methods described above, we can also decorate around the furniture with LED strip lights. If you have a dressing table in your bedroom, you can also put the LED strip lights behind or in front of the mirror, so that it can be used for lighting as well as a supplementary light for taking photos. You canât miss it.
What are the key features of LED strips lights that we care about in bedroom design? A well designed, small, and inconspicuous lighting solution always has a strong visual impact. Decorators love them for that reason, and generally they wonât bother you with any neon, blaring or distracting lights. There are several features we should take into consideration before purchasing LED strip lights for the bedroom.
#1. Color
Basically, the color of the LED light strip is mainly determined by the decoration style and hue of your house. We usually use warm white light and natural white light for rooms, and sometimes we also use RGB light with a controller to change the colors to create a more colorful world. In fact, the bedroom is the main resting place for people. The light in the bedroom is not just about the lighting, itâs also about the atmosphere and sleep. Then when we choose bedroom LED strip lights, it is better to select low-illumination/low color temperature lights instead of much brighter or dazzling ones. For example, we can use a yellow light source to create a warm sleeping environment, which can give people an intimate and lively feeling.
#2. APP Control & Voice Control
When using lights in the bedroom, convenience is a very important factor. Nowadays, smart LED strip lights it is possible to turn the LED lights on or off and change the colors, brightness and modes with Lepro+ App or voice control via Alexa &Google Assistant. We donât need to worry about hitting the foot of the bed at night any more.
#3. Brightness & Dimmable
In general, bedrooms need to be less bright than kitchens and bathrooms. When we choose LED strip lights for bedrooms, we should take this into consideration. And as the time of day changes, we need different levels of brightness, so that we also need a dimmer to adjust it. LED strip lights with a dimmer can also save more energy.
#4. Safety
We spend about eight hours a day in the bedroom, and ensuring we are safe is very important. When we choose bedroom LED strip lights, we need to take a look at their safety rating and choose some reliable brands like Lepro, so that we can be more at ease when using our bedroom lighting.
After introducing the most popular bedroom LED strip lights ideas and the key features we should care about when choosing lights for the bedroom, Iâd love to recommend Lepro LED strip lights, there are plenty of types available. When youâre thinking about what the best bedroom LED strip lights are, and whether or not the lights will fit in your home. Just have a check and find the most suitable LED strip lights for your bedroom.
