5 Best Security Lights for Your Backyard
Whoever said one needs to put an end to hosting or taking a dip in the pool after-hours in the backyard accounting for the poor lighting. By installing backyard illuminants, not only can you entertain all night long but can also boost outdoor ambiance, eliminate the risk of injury, avoid mishaps, and protect your property from an unseen menace.
How to Light up Backyards
Backyard illumination may primarily be categorized into three ranging from safety lighting to prevent unlawful forced entry, offer better visibility, and allow safer navigation, landscape lighting to accentuate the aesthetics of the garden features, and accent lighting to highlight and enhance the hardscape. Whatever vibe you are going for, employing quality outdoor lights can transform your patio into an enchanting haven and give your space that oomph in conjunction with automating the backyard with innovative home technology. We composed this guide with the intention of offering a thorough and holistic understanding of the best and most highly-rated outdoor security lights in the market for your backyard lighting.
List of Best Security Lights for Backyard Lighting
- Lepro 50W Outdoor LED Flood Light
- RAB Lighting Super Stealth Bullet Floods
- Mr. Beams Outdoor Motion Sensor Light
- URPOWER Solar Lights Outdoor
- LEONLITE LED Motion Sensor Flood Lights
1. Lepro 50W Outdoor LED Flood Light with Motion Sensor: Best Overall
A safety light is typically the brightest backyard illuminant available and an optimal choice for security lighting purposes, helping illuminate vast areas, thereby fending off and keeping vicious animals and prospective intruders at arm’s length. This exceptional illuminant is ideal for those night owls who come stumbling through the wee hours of the night, facilitating enhanced visibility in the backyard.
The perfect replacement for a 350W traditional incandescent light bulb, the Lepro 50W LED flood light can save over 85% of power and slash energy costs on your electricity bill. This professional commercial-grade lamp comes escorted by a powerful infrared sensing function, making for a user-friendly, instant-on, and energy-saving solution. Owing to the lamp’s remarkable manual control mechanism, the sensing distance, time, angle direction, and illumination can be hand-actuated. Backed by the IP65 certification, the Lepro 50W LED flood light with motion sensor can withstand dust ingress and low-pressure water jets from any direction.
- Flexible sensor head.
- IP65 Certified.
- 120-degree wide beam detection angle.
2. RAB Lighting Super Stealth Bullet Floods
The RAB Super Stealth Bullet Floods are characterized by an outstanding warranty, a system that can detect movement in real-time, and quality weatherproof housing.
Thanks to the outdoor motion sensor lights being prewired in advance, they are easy to install. However, it is essential to remember not to install them along with multiple adapters on the same circuit as this can lead to an electrical overload, which can cause overheating and burn out the circuit board. Consequently, this can also result in a potential fire hazard.
The only flaw or handicap behind this illuminant is that they are LED incompatible, resulting in escalated utility charges and a higher frequency of replacing bulbs.
- Possesses an evening timer.
- Advanced motion detection logic.
- 10-year warranty.
- Wind can trigger the sensor.
- No LED compatibility.
3. Mr. Beams Outdoor Motion Sensor Light
Over the course of the years, Mr. Beams lights have proved to be an appropriate choice for those on the lookout for a wireless outdoor security light that tenders perks such as convenient installation and 24-hour surveillance as soon as motion is detected through the sensor.
Since these highly versatile illuminants need not be hardwired, they may be mounted not only in the backyard but anywhere where extra security and protection is required—by the house, near a shed, or other outbuildings.
Though these lights offer a list of benefits, they are not as bright as some of the other brands jotted in the guide. Hence, one needs to think twice and estimate how many of these lights are required in total before making the investment.
- Auto shut-off
- Easy installation
- Up to 1 year of battery life
- Less illumination
- Limited motion detection range (10 ft. max.)
4. URPOWER Solar Lights Outdoor
The URPOWER four-pack motion-sensor lights deliver bright light and ensure maximum visibility all the way from the driveway to the entryway avoiding accidents and faltering while trying to get to the front door. For best results, the illuminants should be placed in the presence of direct sunlight for 4 to 6 hours. Once charged and the sensor is triggered, their internal batteries pump out enough juice and generate luminous light that lasts 30 seconds within 10 feet of the smart motion sensors.
- Charges in a matter of 4 to 6 hours when placed under direct sunlight.
- Lights up when motion is detected within 10 feet.
- Lights stay on for 30 seconds once motion is detected.
- The four-pack helps illuminate steps, entryways, and paths.
- It can be installed solely on a flat surface with the screws that come with it.
5. LEONLITE LED Motion Sensor Flood Lights
These industrial-grade motion detection lights can be mounted on the front, side, or back entrance for better protection. This product comes accompanied by a highly sensitive motion detection sensing element with a range of 70 feet and a 180-degree detection angle. It also comes equipped with high-powered dual lights that support and offer a color temperature option of 3,000K for warm white light or 5,000K for daylight.
The Leonlite outdoor motion detector light featuring the dusk-to-dawn sensor, on activation, automatically powers on and off the LEDs and renders about 1,800 lumens of radiant light, saving the hassle of turning them on and off throughout the day. Additionally, this illuminant may also be used without the dusk-to-dawn mode, where it can be manually activated, thereby driving down the energy costs.
- Industrial-level LED floodlight.
- Motion-sensing range of 70 feet and a 180-degree detection angle.
- Provides an output of 1,800 lumens of light on detecting motion.
- Dusk-to-dawn sensor or manually controllable option.
- Requires hard-wiring.
- Emits an extremely bright light than what some users (or their neighbors) are used to or desire.
