5 Popular Headlamps You Can Take on Your Next Camping Trip
Many people worldwide enjoy getting in touch with nature and escaping their busy lifestyles by camping. Spending time in the wild can be great, but it’s important to remember you still need light to see in the dark. After all, there is no electricity in the woods.
A flashlight is helpful in illuminating an area, but your hands will be occupied with holding it. If you need your hands free to carry on with other tasks, you need another kind of light to assist you. This is where camping headlights are beneficial.
3 Primary Factors to Keep in Mind When Buying Camping Headlamps
The primary job of a camping headlamp is to provide you with plenty of light to see what you’re doing and going while keeping your hands free to do other things. As such, there are several important factors to remember when shopping for one.
Camping Headlamps Design
The majority of camping headlamps use the same design – the light is on a strap that wraps around your head and in the front center of that band. Bear in mind that this strap can be either Velcro or elastic; the light may or may not be right in the center of your forehead, and some headlamps would be better attached to a hat of some type.
Size and Weight of Camping Head Torches
A headlamp’s size and weight can determine if one option is better than another for you. While some offer some adjustability, this is not always the case. For those who do, you may find that the headlamp is better for children while another is better for adults. However, you may also find headlamps for both children and adults that can be adjusted to fit the head size.
The adjustment size of the strap will ultimately affect your decision on whether or not the headlamp is right for you.
Another primary consideration of a headlamp is its weight. Children-designed headlamps weigh less because it’s designed to support their small neck and head.
Camping Headlamp Power Type
Headlamps are often equipped with LEDs or built-in light bulbs; their powering source will differ. In most cases, these headlamps have two kinds of power:
- Battery-Powered – The cheapest option to power a headlamp is batteries, but the lower cost you pay initially is often offset by the price you replace the batteries.
- Rechargeable – This option is rather convenient but uses a plug-in charging cord or other charger designed for the headlamp. With this type of power ability, batteries are not needed. On the downside, you’ll need to recharge it while on a trip.
Remember, every headlamp is not equal. When shopping for one, make sure you know what it is you’re looking for in a headlamp. This will narrow your choices considerably and make it easier to find the right one. However, if you need a little help, consider the five choices listed below.
Best Worthwhile Camping Headlamps to Use on Your Next Excursion
Lepro LED Headlamp Rechargeable (Water-Resistant Headlamp)
The name Lepro is well-known in the industry, and when it comes to headlamps, it’s still one of the best. If you want reliability from your headlamp, Lepro offers it with its lightweight and comfortable design. It also ensures your hands will be free to use when wearing it.
Lepro designed its headlamp to include six lighting modes: a high/low spotlight, a high/low flood light, and a constant/flashing red light. It’s also highly resistant to damage – whether dropped or exposed to severe weather.
A single charge can give you up to 15 hours of steady light.
Black Diamond Wiz (Kids’ Camping Headlamp)
Make your kids’ camping or backyard time fun with rainbow lights from Black Diamond Wiz. It’s the beautiful light show of colors, of a rainbow, that makes this a top contender for headlamps for kids. The Wiz’s control mechanism is a little complex, but your kids can click through the different colors to find their ideal setting. Most other kid headlamp models have just white and red lights, which makes this headlamp so interesting and fun.
The lumens output of this lamp is 30, which is usually more than enough for kids and won’t cause temporary blindness to other kids or you. Best of all, if your kid fails to remember to turn off the lamp, it shuts off automatically after two hours.
DanForce Headlamp (On-The-Job Headlamp)
Camping is just one way to use a headlamp, meaning it’s not the only situation where a headlamp can be helpful. There are all kinds of situations where you need more light, which is why DanForce came up with its version.
Their durable headlamp can be used on your head or placed on a helmet or hat to use when partaking in a hobby or job. This headlamp is so durable because it’s resistant to dust, debris, water and damage caused by being dropped. Its head strap is also absorbent, so it won’t become uncomfortable when you sweat and won’t become overheated.
It gives off more than 1,000 lumens, which is plenty of light to see what you are doing.
Foxelli LED Headlamp Flashlight (On-The-Go Headlamp)
If you want an easy-to-use, comfortable, lightweight headlamp, you want to look at the Foxelli LED Headlamp Flashlight. It’s designed, so you’re not worrying about additional pressure on your head or body.
The head strap is adjustable, so there’s no worry that it’ll be too loose or tight on your head. Although it’s got a small light, it’s pretty powerful, even with its three AAA batteries, to see what you need in the dark.
Another significant aspect is that it can withstand weather conditions of all types, ensuring you can use it any time you want – no matter what season it is.
GearLight LED Head Lamp (Adjustable Headlamp)
One of the biggest obstacles people have when buying a headlamp is whether or not the headlamp will fit. The great thing about this GearLight headlamp is that it’s got an adjustable strap to fit any size head – whether children or adults.
GearLight has ensured it has a lightweight design, which means no unnecessary neck strain because of the added weight. It comes with seven different light modes and is extremely powerful even though it uses three AAA batteries.
GearLight also made sure to provide you with two headlamps in the set. Use the second as a spare or share with someone else.
Click to know more about Lepro LED headlamps for your next camping trip.
