Smart Lighting - Ultimate Guide to Google Home Light Bulbs
All of us who use Android devices or other Google-friendly devices would benefit greatly from having access to smart lights that are compatible with Google Home. Having a smart lighting system installed in your house that allows you to control the lights with your voice and in a more efficient manner than with traditional means is fantastic, but where do you even begin?
There seems to be an infinite number of different Google smart light bulbs available, each with a unique set of characteristics, such as connectivity with Apple HomeKit, support for Amazon Alexa, or the ability to instantly alter the color temperature. To help you narrow down your options, we've reviewed the top-rated smart bulbs that are compatible with Google Home and the Google Home app, allowing you to "talk" to your lighting system using voice commands.
What's the Point of Google Smart Light Bulbs?
We're not trying to convince you that everyone needs smart lights, but once they're set up, you'll really appreciate their convenience. You can control the brightness of your home's lights with the touch of an app button, the sound of your voice, or even a smart light switch.
Smart lights frequently include a variety of helpful capabilities, including the capacity to emit various colors or tones and the ability to dim them to the amount you need. Imagine them as a more advanced version of the lights you already possess, with the added ease of being able to walk around your house speaking to the lights rather than having to find a switch. How helpful would it be to enter a pitch-black room and attempt to talk your way out of the predicament?
Does Using Google Smart Bulbs Need a Hub?
You essentially already have a smart hub if you use Google Home for your smart home. This is so that Google Home Hub can control every aspect of your house in an intuitive and easy-to-understand manner. Although many smart bulbs and smart lighting systems don't really need a separate device to link with them, it's still wise to check before you make a purchase. Comparing systems like Philips Hue, which require a separate bridge, to lightbulbs that can function independently and link directly to your Google Home Hub, there are pros and cons to each.
Top Smart Lights for Google Home and Google Assistant
Lepro GU10 WiFi Smart Bulb
Alexa (including Echo, Echo Dot, and more) and Google Home-compatible Lepro LED WiFi Smart Bulb enables hands-free voice control of lights. Using the free "Smart Life" app, lighting may be easily controlled from anywhere at any time. Only 2.4 GHz Wi-Fi is needed; no hub is needed.
You may pick from 16 million colors to suit your mood, or use 2700-6500 kelvin warm to cold white light with adjustable brightness to create the ideal atmosphere. Also, you decide on white for the ambient lighting. For daily use, pick a white light tone between 2700K and 6500K. Warmer lighting is for a pleasant, comforting environment, and cooler lighting is for reviving, focusing, or energizing. You may adjust the brightness from 1% to 100% depending on your needs.
Starting Package for Philips Hue
Because Philips Hue is such a well-made technology, it is well-known in the smart lighting industry. Although it needs a second Philips Hue hub or bridge to function, once set up, it is a strong lighting system. You can effortlessly automate your house with the choice of colored or white lights, and it works with all major systems including Google Home. After installation, more lights couple up in a matter of seconds, allowing you to swiftly set up your whole house. For extra convenience, Philips Hue also offers other products like dimmer switches and motion sensors. While pricey, it is the ideal choice for a whole-home solution.
Smart Light Bulbs from Sengled
It's crucial to choose a smart light bulb from Sengled's large selection that works with Google Home and doesn't require a hub. This one accomplishes all of that while allowing you to create moodscapes and change the brightness in accordance with your goals. You'll have complete control over this situation thanks to the Sengled Home app's scheduling functions. Bulb groups are simple to create, allowing you to provide a single voice command to manage a whole room (or house). Please keep an eye out for sporadic connectivity problems.
Smart Light Bulbs from Lumiman
Lumiman is another affordable brand of smart lighting that has all the features you could possibly require. Lumian's WiFi-enabled smart light bulb can display over a billion possible hues. in addition to white alone, and you can quickly convey your requirements by voice or smartphone without the need for a hub. Things may be scheduled, as well as timers and groups set up. Although the app isn't the best, Google Home's voice commands work just fine. For the price, the lights themselves are very brilliant. You'll need a 2.4 GHz WiFi network to utilize them, as is nearly often the case.
Smart Bulb by Wyze Labs
In spite of the fact that Wyze Lab's smart bulbs aren't as obviously labeled for Google Home as those of some more well-known companies, they function just as effectively with this voice assistant as they do with others. You may enjoy from up to 1,100 lumens/75W with a vibrant selection of 16 million colors at a comparatively affordable price. White light color-temperature settings are also available, as you might anticipate given that everything is voice- or app-controlled. Despite the software being a little basic, scheduling and automation are quite simple to set up, and custom settings are also easily accessible via commands. Particularly given the cost, color rendering appears to be done rather well here.
After learning how to choose Google home light bulbs, I want to highly recommend the LED smart light bulbs from Lepro. Lepro provides high-quality Gu10, E12, E26, and BR30 LED smart bulbs to meet your different needs in running.
