How to Install Outdoor LED Flood Lights - Easy to Follow Installation Guide
LED flood lights are widely used for gardens, backyards, garages, parking lot lighting, and more. This page introduces how to install LED flood lights.
Simple Guide to Install LED Flood Light
Do not need to fix to wall, ground or others. No special tools required.
Step1. Cut off the power
To start with, please turn off the main power for safety reasons.
how to install flood light
Step 2. Connect the wires
After fixing the light components, connect the wires according to the mark of the fire wire, the zero wire, and the ground wire.
how to install flood lights
Step 3. Adjust the angle
After the light wires are connected, adjust the projection angle of the light using the open end wrench.
installing flood lights
Step 4. Turn on the LED flood light
After the installation, please turn the switch on and test whether the light is on. If so, the installation is complete.
how to install outdoor flood lights
Advanced Installation Guide of LED Flood Light
If you want to make the flood light more stable, or keep it from being taken away, you can fix the lights to the wall or the ground.
Tools: open end wrench, electric screwdriver, impact drill, and hammer.
To begin with, please follow the 4 simple steps above.
Step 5. Make a punch mark on the surface to be installed.
flood light installation
Step 6. Select appropriate drill bit, punch a hole with the impact drill, and knock the expansion screw into the hole first.
flood light wiring
Step 7. Take out the light components, align the mounting hole of the light bracket with the punched hole, fix the bracket by inserting the self-tapping screw with a power screwdriver. If the expansion bolt is used, align the bracket mounting hole with the bolt and tighten the nut with an open end wrench.
how to install a floodlight
If you buy LED flood lights with motion sensor, on additional step after standard step 2:
Additional step: After the light wires are connected, adjust the lighting, time, and distance knob on the sensor head, and adjust the projection angle of the lamp through the open end wrench.
how to wire flood light
