The Top 5 Handheld Flashlight Pens of 2024
Penlights are compact, pen-shaped flashlights popular amongst professionals in the medical, law enforcement, and mechanical fields. The most effective pen flashlights are lightweight, small, and easy to carry. They've recently become the norm for people who want a simple-to-operate flashlight. They are conveniently small and may be tucked away in a purse or a pocket. It might be difficult to decide which one to buy, but if you have the right information, the process will be much smoother. Check out the list we've collected below for some suggestions.
Pen flashlights are used by a wide variety of occupations, from physicians and mechanics to police officers. To get the greatest penlights for any purpose, you have arrived at the correct spot. Here are the top five penlights available today. They were put through rigorous testing and analysis and then rated according to how they fared in the tests.
Top 5 List of Pen Fashlights of 2024
LE Pocket Pen Torch Light Flashlight
The tiny design of the LE pocket pen torch flashlight makes it ideal for use in illuminating work locations with restricted access to light. Dimensionally, it measures at 1.6 centimeters by 13.2 centimeters and has a mass of 29 grams. It means it won't add much weight to your bag if you take it with you. You may clip it to your belt, backpack, binder, shirt, or trouser pocket thanks to its detachable pocket clip.
These pencil torches have high, low, and SOS settings and they run on 3 AA batteries (not supplied). It's weatherproof against rain and snow thanks to its construction from long-lasting aluminum alloy and its IPX4 rating.
Stylus Pro USB Penlight from Streamlight
With our combined 16 years of firefighting experience, we've put in a lot of time at firehouse quarters. In recent years, the Streamlight Stylus Pro Penlight has become the standard penlight for first responders. This robust penlight's Type II MIL-Spec anodized coating and IPX4 water and impact resistance compliment the LED light's incredibly high brightness, which is consistently regulated at 70 lumens and 630 candelas.
Furthermore, it has a USB rechargeable battery, a built-in pocket clip, and a push-button tail switch that allows for temporary or steady on/off lighting.
Coast Rechargeable LED Penlight HP3R
Whether you're going camping, trekking, or just need a little extra light around the house, this small penlight is ideal. It has a built-in clip so you may keep it in your pocket or a shirt. Changing from floodlight to spotlight is as simple as twisting the focusing optic, and the whole thing is made to be extremely user-friendly.
Considering its little size, it can provide 385 lumens. Either the included standard AA batteries or the integrated USB-rechargeable battery pack may power it for months. The IP54 rating guarantees protection against dust and water. Moreover, it comes with a lifetime guarantee.
Stylus LED Penlight by Streamlight
the Microstream Stylus LED Penlight is the most compact and lightweight penlight on this list at just 1.1 ounces. Its high-intensity LED light lasts for 100,000 hours and its pen-like form makes it ideal for use in the medical field. This penlight is tough and operational enough for everyday professional use thanks to its water-resistant aluminum housing, anodized finish with anti-slip grip, incorporated pocket clip, and brief and consistent switches, although it may not withstand the same stringent outdoor use as the aforementioned tactical penlights.
Nitecore MT06MD Medical Penlight
You'll be pleased you had this penlight in your coat pocket at all times. The default setting is a dim 4 lumens to protect patients' eyes, but it can be cranked up to 180 lumens for use as a powerful flashlight or security light. The high CRI and diffused light make this lamp suitable for medical usage, particularly in examining the eyes and diagnosing injuries.
It's a convenient tiny light that can operate for up to 35 hours on only two AAA batteries, making it ideal for any situation in which you'd benefit from having a small, portable penlight. Furthermore, it can withstand being submerged in water up to 2 meters deep (IPX8). There are better alternatives out there, but not at this pricing.
Considerations for Choosing the Finest Pen Lights
Weight and Measurements
Remember to double-check the length and the associated weight. Find a dependable and portable penlight by comparing this with the design aspects. In such case, make sure to double-check if the stated weight is with or without the batteries.
High-Quality Build
There is no danger in investing in a quality flashlight from a trusted manufacturer. That's why you know their items will look and feel great while still being functional.
Is the Light Beam Strong?
Because it defeats the purpose if your shiny new penlight can't illuminate a dark room. There should be a variety of brightness levels available on a contemporary penlight's mode switch. So how many lumens can it produce at its peak? Maximum brightness needs to be somewhere in the region of 70â80lm; obviously, higher values are preferable.
Is it powered by rechargeable batteries? Longevity of the battery?
LED penlights may have rechargeable batteries already installed. In the long run, rechargeable flashlights save the user a lot of money. The fact that they can be replaced is of little consequence. Remember to check the maximum runtime, which ought to total at least 3-4 hours.
Additional Benefits All Around
With certain flashlights, the bulb may be removed from the device. Several of them have a two-way clip. Consistently useful perks like these are rare to find.
Pen Flashlight VS. Tactical Flashlight
Not all tactical flashlights have the same form as pens, but pens are the universal standard for the shape of a penlight.
- As opposed to a tactical light, a penlight doesn't produce nearly as many lumens.
- An average pen light can be recharged in a fraction of the time it takes to charge a tactical light.
- When compared to a flashlight, the light beam from a penlight is far more concentrated and focused.
- Lightweight and compact, pen lights are a tactical need
- Although tactical lights' user interfaces might be complicated, the functioning of any penlight is straightforward.
