5 Rechargeable Camping Lanterns That Make the Grade and Brighten Spaces
One of the more essential camping tools in your arsenal is a lantern. After all, the light source will help you to prepare meals at dusk or when you need light to find your way around an area late at night. Camping lanterns have a plethora of benefits to them, and as such, there are many of them on the market to choose from. Some lanterns work off batteries, some use kerosene, and others are rechargeable, getting their power from the sun.
Many of these rechargeable lanterns offer an array of functionalities, such as mood-setting color options or power banks. They are also much more convenient than battery or kerosene lanterns, as there is no need to carry spare batteries or kerosene with you when camping.
The latest lanterns come with lightweight, fast-charging internal batteries that can also be used to charge other devices in cases of emergencies.
3 Factors to Consider with Rechargeable Camping Lanterns
Battery Life
When choosing a lantern, you want one that offers a long-lasting battery that can be used for hours away from any power source. Some manufacturers choose to use shorter battery lifespans than others, which is something to be mindful of when buying your lantern. If you’re unsure how long you’ll need light, it’s best to go for a lantern with the longest battery lifespan possible. You just never know what could happen.
Utility
Ask yourself how you plan to use the lantern. Will it be for decorative purposes, or will it be used to walk around in the dark? There are pros and cons to each consideration, but knowing how the lamp will be used helps narrow down the market choices.
Weight and Size
Lanterns are designed in various weights and sizes. Some are designed to brighten a whole area, while some are designed to be stylish. Plus, your lamp goes in with the rest of your camping gear, so you want it to be portable and lightweight. If you’re going to do a lot of walking, you definitely don’t want to be carrying a heavy lantern. However, if you plan to stay in one place for a period of time, then you want to go with something a little bigger that gives more light.
5 Popular Rechargeable Lanterns to Take on Your Next Camping Excursion
LE Rechargeable Camping Lantern
When the brightness is what you need for any outdoor event, the LE Rechargeable Camping Lantern can meet the need. The manufacturer ensured that this one provides up to 1,000 lumens, equating to a 75W halogen bulb. The lantern’s outer case will give off a soft light that can be changed from cool white, and warm white to neutral white. In flashing mode, all three can be used. The brightness is adjusted by pressing the button for a long time.
LE designed this rechargeable camping lantern to include a USB port so that USB charging devices like phones or laptops could be used for a short time. It also comes with a hook, allowing users to hang it up to brighten a bigger area of space. With an IP44 rating, the lantern can withstand water splashed on it – great for snow or light rainy days.
DARMAI Rechargeable Camping Lantern
You don’t want to be caught in the dark on a camping trip. The DARMAI rechargeable camping lantern is a multifunctional LED light that includes both lantern and torch modes that boost its flexibility. It comes with six light modes, including a red warning mode that can be used in emergencies.
The manufacturer ensured it provided a lot of power, with 800 lumens in torch mode that can last a maximum of four hours. It can be seen for distances of 250 meters. It can run at 70LM for eight hours and 130LM for less than four hours as a lamp.
If you plan to do a lot of walking, you’ll want something else entirely because it’s a bit bulky to carry.
Harper Living Rechargeable Camping Lantern
If you’re looking for style, the Harper Living Rechargeable Camping Lantern brings out the 19th-century look in its water-resistant product. Designed with a 75-hour battery life, it’s ideal for anyone who plans to stay out for a long time. You can adjust the light’s brightness and warmth using the metal rotary button located at the lamp’s base, giving campers the opportunity to set up the device how they want.
It also comes with a cable hanging rope so campers can hang it up over the campsite – great since this lantern is a bit heavier than other products on the market and is designed mainly for stationary use.
Nite Ize Radiant 314 Rechargeable Lantern
This is the powerhouse of all lanterns with all it provides at an affordable price. It’s not very heavy, with a weight of 10 ounces, and doesn’t take up a lot of space in a bag. Change the light color to a yellow ambient light for nighttime use and turn it bright white when necessary. Use the hook at the top to hang over your campsite or tent.
If the battery in your tablet or smartphone needs charging, Nite Ize made sure to offer ports for charging them.
Ozark Trail Rechargeable Lantern
Walmart is responsible for the emergence of the Ozark Trail Rechargeable Lantern, which is quite reasonably priced compared to similar products on the market. This is the way to go when you need a budget-friendly camping lantern.
It offers a bright rechargeable light that produces 700 lumens, which can brighten up any tent or campsite and last up to 275 hours. It’s a solid model and offers an easy-to-use design that will rival other budget-friendly lantern lights currently on the market.
