A19 LED Bulbs
LE LampUX Smart WiFi E26 Light Bulb, 60W Equivalent Led Bulbs, Compatible with Alexa Google Assistant, No Hub Required, Dimmable, Warm White A19 App Control Smart Light (9W, 2 Pack)
- Light Color: RGBW
- Brightness (lm): 850
- Base Type: E26
- Package Quantity: Pack of 2 Units
- Color Temperature (K): RGB+2700
- Power Consumption (W): 9
LE WiFi Smart Light Bulb Works with Alexa, Google Assistant, IFTTT, 2.4G WiFi, RGBCW and CCT (2700-6500K Tunable White), Timer, Color Changing, Dimmable 9W 806lm A19 E26 LED Bulb, No Hub Required (4 Packs)
- Light Color: RGB+CCT
- Brightness (lm): 806
- Base Type: E26
- Package Quantity: Pack of 4 Units
- Color Temperature (K): 2700-6500K
9W RGB WiFi Smart Light Bulb, Works with Alexa, Google Assistant, No Hub Required
- Light Color: RGBW
- Base Type: E26
- Package Quantity: Pack of 1 Unit
LE WiFi Smart Light Bulb Works with Alexa, Google Assistant, IFTTT, 2.4G WiFi, RGBCW and CCT (2700-6500K Tunable White), Timer, Color Changing, Dimmable 9W 850lm A19 E26 LED Bulb, No Hub Required ( 2 pack )
- Base Type: E26
LE iLUX Bluetooth Mesh Smart Light Bulb, RGBW and White Light, No Hub Required, Voice/Music Sync, Dimmable, Color Changing, 9W 800lm A19 E26 LED Bulbs, Programmable APP alternative to DMX512 System
- Light Color: RGBW
- Brightness (lm): 800
- Color Temperature (K): 3000K
LE Vintage Edison Bulb, Dimmable, A19 E26, 40W Incandescent Equivalent, Soft Warm, LED Filament Light Bulb for Wall Sconces, Squirrel Cage Light, Pendant Island Ceiling Chandelier Fixture, Pack of 6
- Light Color: Warm White
- Brightness (lm): 350
- Base Type: E26
- Package Quantity: Pack of 6 Units
- Power Consumption (W): 4
6W RGB LED Bulbs with Remote, 40W Incandescent Equivalent, 16 Color Choices
- Light Color: Multi-colored
- Brightness (lm): 470
- Base Type: E26
- Power Consumption (W): 6
Lighting EVER A19 E26 LED Light Bulb, 8.5W Dimmable, 60 Watt Incandescent, 800 Lumens, 60HZ 5000K Daylight White, 240° Beam Angle for Home, Living Room, Kitchen and More, Pack of 18
- Light Color: Daylight White
- Base Type: E26
- Package Quantity: Pack of 18 Units
- Color Temperature (K): 5000K
- Power Consumption (W): 8.5
LE Pack of 6 Units, 10W A19 E26 LED Bulbs, 240° Flood Beam, 60W Incandescent Bulb Equivalent, 810lm, Warm White, LED Light Bulbs
- Brightness (lm): 810
- Base Type: E26
- Power Consumption (W): 10
9W Alexa Light Bulb, Warm White, 2700K, 9W 850lm 60W Equivalent, Dimmable, A19, E26
- Base Type: E26
