Top 5 Dimmable LED High Bay Lights
Can LED high bay lights be dimmed?
It depends. First of all, you need to prepare a dimmer, as regular LED high bay light packages do not normally come with one. Secondly, confirm whether the LED high bay light has a dimming cable; if it does, then yes, it can be dimmed.
How to dim LED high bay lights?
If the LED high bay lights purchased are dimmable, use a dimmer to connect two dimming cables. Taking Lepro LED high bay lights as an example, these can be dimmed from 1 V to 10 V. The purple cable represents dimming up (+), while the gray cable represents dimming down (–). The dimming function can be used once the corresponding cable is connected. This way, you can reduce power consumption at any time by adjusting the brightness of the light, so as to achieve the aim of energy saving.
Of course, if the dimming function of the LED high bay light is not required, the two dimming cables can be ignored.
Best 5 Dimmable LED High Bay Lights
1. Lepro Dimmable UFO LED High Bay Lights
  • Power Consumption (W): 100/150
  • Metal Halide Equivalent (W): 300/400
  • Brightness (lm): 13000/19000
  • Color Temperature (K): 5000
  • Beam Angle (Degree): 120
  • Warranty: 5 Years
Lepro LED high bay lights come with two dimming cables, as shown in the figure above, where the purple cable represents dimming up (+), while the gray cable represents dimming down (–). If required, remove the protective cap and connect the dimmer to carry out dimming from 1 V to 10 V. If dimming is not required, the two cables can be ignored.
Lepro LED high bay lights have UL and DLC certification, and quality is guaranteed. At the same time, the price is very affordable. The brightness of the 100W Dimmable UFO LED High Bay Light is 14500lm and the price of the 150W Dimmable UFO LED High Bay Light is 21750lm.
Aside from UFO LED high bay lights, Lepro also carries many different kinds of linear LED high bay lights, which also support dimming from 1 V to 10 V. Look them up for more information.
2. HYPERLITE 1–10V Dimmable UFO LED High Bay Lights
  • Brightness (lm): 14000/21000
  • Warranty: 5 Years
HYPERLITE UFO LED High Bay Lights similarly support dimming from 1 V to 10 V. This LED high bay light model has high luminous efficiency of up to 140 lumens per watt. Accordingly, the price will also be more expensive, with the 100W model priced at $79.99. Budget considerations aside, it is a good choice.
3. Hykolity Dimmable UFO LED High Bay Lights
  • Power Consumption (W): 150/200
  • Brightness (lm): 21000/28000
  • Warranty: 5 Years
200W Hykolity UFO LED High Bay Lights have a brightness output of 28,000 lm, which is equivalent to 400 W MH, and saves 80% on electricity bills. Whether it is installed in a warehouse, garage, workshop, or gymnasium, the dimming function can be used to adjust the brightness from 1 V to 10 V, so as to save more energy.
4. Royana 1–10V Dimmable Warehouse UFO LED High Bay Lights
  • Power Consumption (W): 100/200
  • Brightness (lm): 10000/20000
  • Color Temperature (K): 6500
  • Warranty: 2 Years
Royana UFO High Bay Lights can be connected to a 1–10 V dimmer to adjust the brightness of the light under different conditions. These have CE and ROHS certification, and the protection grade is IP65, which makes them suitable for use in various harsh environments, both indoors and outdoors. The 100W Royana UFO High Bay Light is priced at $59.99, but the warranty period covers only two years. For the same price, the Lepro 100W UFO High Bay Light offers better quality assurance.
5. JOMITOP Dimmable Commercial UFO High Bay
  • Brightness (lm): 15000/225000
  • Warranty: 5 Years
JOMITOP UFO High Bay Lights have ETL certification and high power at 140–150 lumens per watt. The 150W model is priced at $69.99, which is relatively affordable. It is dimmable from 1 V to 10 V, but the package does not come with a dimmer. When installing the dimmer and connecting the dimming cable, please take care to disconnect the power supply. In addition, please also take care not to expose the power cable even if you do not require the use of the dimming function.
