Best Outdoor LED Pole Lights Review in 2024
Cities looking to light up their outdoor spaces, roads and walkways have many products they can consider, including LED pole lights. These lights are already seen in parking lots and other outdoor settings and are identified by their downward light feature. It’s a simple design, with a pole top-mounting system that ensures dark sky compliance.
LED pole light manufacturers are working toward the replacement of conventional HPS lighting (metal halide lights). As such, these light heads offer fantastic coverage of the area installed, boosting both visibility and security even when it’s super dark outside.
Types of outdoor LED pole lights
There are several kinds of commercial outdoor LED pole lights that can be considered, including but not limited to:
  • Cobra Head LED Street Light
  • LED Barn Lights
  • LED Post Top Light
  • LED Shoebox Light
  • Solar Street Lights
What would make any of these lights ideal for your home or area? Consider the seven manufactured LED pole lights available and think about how they can meet your lighting needs.
Best 7 LED Pole Lights Reviews 2024
  1. Lepro 150W LED Shoebox Light with Photocell
  2. LEDMO 200W LED Street Parking Lot Lights
  3. Superior Lighting 65W LED Dusk to Dawn Light
  4. LEONLITE LED Barn Light, Daylight 5000K-75W
  5. Solar Light Mart ALPHA 1080X Street Light
  6. TENKOO 150W LED Solar Street Light
  7. WARELIGHT COBRA HEAD ROADWAY LIGHT,
When it comes to the best lighting output, you can’t get much better than the Lepro 150W LED parking lot light, with its 19,500 white light lumens that equate to 50,000 hours of lifespan. It’s nearly identical to the 400W of metal halide lamps. It’s been outfitted with a photocell sensor, so it detects when it’s dusk and dawn, turning on or off the light.
There is so much installed in the shoebox casing, and its function remains one of the best. It offers dust protection ranking UL security standard and meets the DLC rebate qualification certification. On top of that, Lepro offers a five-year warranty on its product.
Lepro also offers other lighting models besides the 150W. Options include 100W, 200W and 300W LED lights, which are primarily used for commercial purposes like streets, parking lots, stadiums, roads, sidewalks, etc.
  • Dust to Dawn & Dimmable
  • Super Energy Saving
  • DLC rebate qualification certification
  • 50,000 hours lifespan & 5 year warranty
LEDMO is another LED light company that makes top-of-the-line LED street lights. For this one, it’s installed a dusk-to-dawn photocell sensor that will perceive ambient light and turn the light on or off. The manufacturer created a hollow-out heat sink design to dissipate heat better and make the product lighter.
Being 200W, it’s really bright, giving off 26,000 lumens. Its high-quality lamp does not project any UV or IR radiation, protecting the environment. The manufacturer included a five-year warranty if there were any unforeseen issues, but you don’t get the typical flickering or buzzing seen with other pole lights on the market.
  • No buzzing or flickering
  • 50,000h lifespan
  • Energy saving
  • Easy Installation
  • The quality is not that great.
The 65 Watt LED dusk-to-dawn security light gives off 85,000 lumens, making it one of the brightest offered on the market. It’s extremely durable, but it’s got a short mounting arm, and it’s not easy to install.
The barn light LED is equivalent to what you’d see with a 250-watt high-pressure sodium flood light or 250-watt mercury vapor, and you’ll save on energy consumption. Whether installed on a LED pole light or a 20-foot high wall, it can brighten any barn or building. Due to its brightness, it offers a security element to it.
  • Extended active life
  • Well illuminated
  • Impressive area coverage
  • Ensures you save on energy consumption
  • Installation is not easy
  • The mounting arm is short
Give your home’s lighting a little uniqueness with barn lights from LEONLITE. The manufacturer designed its LED barn light to accentuate any home décor. It’s got a 75-watt and 5000K daylight rating. The company also designed it so that it’s got an IP65 waterproof and dustproof rating thanks to its robust aluminum casing, making it useful for both interior and exterior uses.
It’s designed to recognize when it needs to come on and go off (evening hours and morning hours), making it a resourceful option for people who want to save energy (and money). It’s got a mounting height between 19 and 57 feet and can cover more than 90 feet of area.
One key drawback is that you must be careful when installing it.
  • Rugged aluminum casing
  • Excellent waterproof design
  • Auto on/off
  • Great energy efficiency
  • Needs a careful installation
When money is a concern, and you’re looking to lower your electric bill, the Alpha 1080 X Street Light is the answer. It’s an affordable, weatherproof, reliable, adjustable, and high-performing street light with tons of features to it. What makes this such a money-saving and power-saving option is its PIR technology, with ultra-sensitive sensors that will detect all motion within the area that turns it on.
It’s designed with three modes that you set based on what your preferences are. However, the PIR function can be disabled so that the light stays on throughout the night until it detects light at dawn.
On the downside, the lights are a bit bulky, and installing them is a bit tricky. Plus, the battery life isn’t as great as other models and takes nearly eight hours to be fully charged. Simply put, this means the overall cost for the light is relatively high.
  • Adjustable mounting bracket
  • Three different modes of operation
  • Weatherproof design
  • Smart PIR Motion and Light Sensor
  • A bit bulky and difficult to install
  • Comparatively more expensive than other models
  • Shorter battery life
There are many reasons to mention the TENKOO LED Solar Street Light. First, it combines LED technology with outstanding solar power to be highly efficient in its brightness and energy consumption. It’s got a powerful 4,200mAh battery that can be charged within 10 hours, ensuring five days of full illumination even when the day is cloudy. There are 28 pieces of energy-efficiency bright LEDs that generate nearly 2,000 lumens, lighting up practically any street corner.
It’s got a compact design that is weather and water-proof, allowing it to withstand elements of all types.
The drawback to the TENKOO model is its installation; a person needs special skills and tools to make sure it’s correctly installed. You also need a specific light post, and getting spare parts isn’t very easy to do if something needs repairing.
  • Equipped with a powerful battery
  • 28 Ultra-bright LEDs
  • Integrated design: Compact and Elegant
  • Waterproof and weatherproof
  • Powerful Motion and Light Sensors
  • Difficult to install
  • Requires special light post
  • Unavailability of spare parts
Warelight Cobra Head Roadway Light
This product offers the best optical performance and flexibility wherever they are installed. It’s best for use along roadways, walkways and in parking lots. The manufacturer has focused on an economical design that includes features such as leading industry surge protection options, outstanding lumen maintenance and a single latch tool-less entry. It can last up to 100,000 hours but does cost a lot.
  • Lifespan: 100,000 hours
  • Listings: cULus, IP66, Wet Location listed
  • Relatively expensive
