How to Install LED Strip Lights - Easy to Follow Installation Guide
The installation guide is for 12V LED strip light kit. LED strip Lights are great for decorating your home. Its simple and superb design can embellish the color of the home stereo space and enhance the atmosphere.
Now you can watch the video or follow the steps below to check how to install, cut and connect LED strip lights.
Part 1. How to Install LED Strip Lights
Part 2. How to Cut LED Lights Strip
Part 3. How to Connect LED Strip Light Sections
Part 1. How to Install LED Strip Lights?
Step 1. Dry and clean the surface
Before adhering any strip lights, clean the surface of the area you will be placing the lights on. This is vital to keeping it mounted for a long time to come. It is recommended to apply your strip lights on smooth stable surfaces. It should not be placed on rough or textured surfaces or any surfaces that can bend or move.
Step 2. Unroll the light strip, stick to the surface
The LED strip lights come rolled on a spool. Simply unroll the length of lighting you will be working with, remove the adhesive backing and stick to the desired surface. Press down on each part of the strip so it is firmly adhered to the surface and has no air bubbles.
You can use fixing clips to strengthen the strip lightâs installation and ensure they stay in place. Peel off the adhesive tape and apply it to the surface with the non-sticky area over the strip light. If you choose, you can secure the clip further by screwing it to the surface.
Notice: Not all of the LED strip lights on lepro.com are equipped with the fixing clips, please check the new models if needed.
Step 3. Connect LED light strip and turn on the light
Once your strip lights are secured, you can attach it to the controller and power adapter, then plug it into an electrical outlet. Using the remote control, remove the insulation sheet first, press any color on the remote control to change the lighting color.
Each strip light has special designated sections where you can cut the strip. Be sure to make a clean straight cut only in these designated sections. Cutting it in a non-designated area will damage the strip lights.
Did you know you can design your strip lights to make twists and turns, go around corners or even over non-flat surfaces? Use the corner or straight flexible connectors and connector clips.
To join two strip light sections together, use a connector clip. Push the open end of each strip into the clip, then close it to lock it in.
To make your light strips go around a corner, use one corner connector and 2 connector clips.
You can even make your strip lights go over uneven surfaces if you need to. Connect a flexible strip connector to the strip lights and over the uneven area. Connect the other end to the rest of the lighting.
Now you can feel free to change and choose the light color atmosphere you want. If you use a remote control, donât forget to unplug the battery insulation sheet before use.
For rough surfaces, you may need to install mounting clips to keep the strip light stable. For moist places like bathrooms, waterproof strip lights are recommended. And now you can check the LED strip lights category to get more.
