5 Emergency Lighting fixtures to Keep You Lit When Electrical Power Off
When the lights at your house suddenly go out, you and your family are thrust into the darkness. Unless you’ve got your smartphone with a light and it’s close by, you’ll be fumbling and stumbling around in the dark trying to find a light. And, when a natural disaster, such as a tornado or hurricane, hits, there is no way to know when your lights will return. An emergency light beyond your smartphone is a necessity.
However, you need to be mindful of what kind of emergency light product you buy for your home. Many emergency lighting products are on the market, but not all live up to expectations. You want a product that you can depend on. When you need light the most, you want only the best product on the market.
List of Best 5 Emergency Lights for a Power Outage:
  1. Lepro 4.2W Daylight White Emergency Light
  2. Amerelle Emergency Lights
  3. HouLight 5W Rechargeable Emergency LED Light Bulbs
  4. OTYTY Emergency Lights
  5. PECTSUN LED Emergency Lights
One of the best emergency lights on the market is the Lepro LED emergency light, which has a 120/277VAC input that offers 90 minutes of emergency lighting when the power goes out. It’s got a 9.6V600mAh Ni-Cd battery that may be recharged 500 times. You get 45,000 minutes of lighting with the Lepro.
With 200lm of emergency lighting, you can place it throughout your home and business – doorways, hallways, stairways, office buildings, etc. It can also be mounted on the ceiling or walls, with the mounting equipment available in the package.
  • UL certification
  • 50,000 hrs lifespan
  • Fire resistant
  • 360° rotation adjustable heads
Hope for the best; prepare for the worst. And, with the Amerelle Emergency Lights, you prepare your home for the worst in case it should happen. The manufacturer of these emergency lights has made them portable and lightweight, allowing you or your loved ones to carry them from one room to the next.
There are six emergency lights in the package, which means everybody in your household can have one, or you can keep one in most, if not all, of the rooms in your home. The manufacturer used a 3.6v 200mAh built-in rechargeable battery that can last up to seven hours if fully charged before the outage. It includes an LED guide light, allowing you to know what the device’s power level is at.
  • Extremely portable and lightweight
  • Can be also used as flashlight or lantern
  • LED charging indicators
  • Each pack contains six devices
  • Construction is not durable
  • Not waterproof and shockproof
  • The battery is not reliable
One of the key differences between this brand of emergency lighting and the others on this list is that it can function as a standard light bulb and becomes an emergency light when the power is out. The lightbulb, which uses less power than incandescent bulbs, has a 40-watt rating that generates 500 lumens. You can use it inside or outside… the choice is yours!
HouLight Emergency LED Light Bulbs
  • Can be used indoors and outdoors
  • 500 lumens
  • Can be used for 4 hours on emergency mode
  • Uses less power compared to regular bulbs
  • Can be used as both a normal lightbulb and as an emergency light
  • Battery packs are not reliable
  • Some issues in electronics and quality
OTYTY Automatic Emergency Lights
The OTYTY can last 90 minutes after the initial power outage, and thanks to its design, it can endure extreme weather conditions, shocks, and fires.
Many people take their electricity for granted, but when the lights go out, you want a product that you can trust will stay on. The OTYTY, which has a robust, heavy-duty steel housing, is designed to be plugged into an electric socket. It has two light LED light heads that you can adjust from side to side at a 180-degree angle.
  • Strong and durable housing
  • Can be used indoors or outdoors
  • 90-minute battery
  • 3-year warranty
  • Short cable
  • Long charging time
SPECTSUN LED Emergency Lights
If your home loses power often, prepare yourself, and your family with the installation of the SPECTSUN LED emergency lights. Wherever you believe the lights will suit you best – bathroom, garage, basement, attic, etc. – you can install the lights to give you that emergency lighting.
What makes the SPECTSUN LED Emergency Lights so worthwhile?
It has a lifetime of 50,000 hours and can last 90 minutes when fully charged. Thanks to its heavy-duty thermoplastic design, it won’t overheat or get too hot to the touch. With a few basic, around-the-house tools, you can easily install emergency lights to your electrical wiring.
SPECTSUN also provides a five-year warranty on its product.
An emergency happens in the blink of an eye! But, if you want to stay one step ahead when your lights go out, you want emergency lights you can trust will keep your family and you safe. With an emergency light (or two or three), you can stay alert to problems that arise and move when it’s time. Don’t be caught in the dark anymore! Use any of the five most sought-after emergency lights on this list, and you’ll never be in the dark again!
  • Bright heads composed of 24 LED lights
  • 50000 hrs lifetime
  • Can run for 90 minutes continuously in emergency mode
  • Easy to install
  • Can only be used indoors
  • Not waterproof
The most important thing to prepare your home for any emergency is to have the best emergency lights for home use. These LED emergency lights will help keep you and your family safe whenever emergencies arise so that you can remain mobile, alert, and ready to move anytime.
