Best 10 LED Parking Lot Lights in 2024
Adequate lighting can make your living environment more comfortable while helping avoid accidents and eliminating the risk of injury. Besides the fundamental lighting luminous flux requirements, the lighting of the parking lot has other aspects such as the uniformity of illuminance, the color rendering, and the color temperature requirements of the light source, which are also critical indicators to measure the quality of lighting. They are explicitly designed to withstand severe weather conditions, moisture, dust, and debris.
Choosing a suitable, high-performance, reliable, and quality parking lot light for your outdoor space is extremely important since high-quality field lighting can create a relaxed and good visual environment for drivers and pedestrians. We have put together a list of ten of the best parking lot lights in the market from a wide range of LED lighting brands for you to go through before making a purchase. Thus, through this article, we will help you find the best and most highly reviewed outdoor pole lights for parking lot lighting in 2022.
List of Best LED Parking Lot Lights in 2024
- Lepro 200W LED Parking Lot Light, Dusk to Dawn Shoebox Light
- Ledmo 200W LED Parking Lot Lights
- LEONLITE 300W LED Parking Lot LightÂ
- RuggedGrad 150-Watt LED NextGen II LED Parking Lot Light
- Lightpolesplus 120w LED, 12" Shoebox Light Fixture
- HYPERLITE LED Parking Lot Light 200W
- AntLux 150W LED Parking Lot Lights
- Hykolity LED Parking-100W Lot Light with Photocell
- EverWatt 300W LED Outdoor Parking Lot Light
- Kadision 150W LED Parking Lot Light with Photocell
1. Lepro 200W LED Parking Lot Light, Dusk to Dawn Shoebox Light
The Lepro 200W LED parking lot outdoor light delivers a maximum output of 26,000lm of 5000K radiant high-performance white light. Equivalent to a 500W metal halide lamp, these luminaires employ outstanding energy-efficient LED chips, thereby saving energy costs by 60%. The Lepro 150W Parking Lot Light also comes accompanied by a dusk-to-dawn photocell sensor that automatically detects variations in light intensity and powers the LED on/off. Thus, it is the ideal choice if your requirements include low cost and high efficiency.
Owing to the fact that this shoebox light fixture complies with UL safety standards and possesses DLC rebate qualification certification, besides offering IP65 waterproofing and being accompanied by an impressive 5-year reliable warranty, we can indeed be assured of an exceptional quality luminaire.
At Lepro, in addition to the 200 W parking lot lights, you also have the alternative of choosing between the 100W, 150W and 300W high wattage LED lights available for large outdoor venues. They are used mainly for commercial purposes and, probable areas include parking lots, streets, roads, gardens, terraces, sidewalks, roads, stadiums, and the like.
- Cost-effective & Energy saving
- Dusk to Dawn Photocell Sensor & Manually dimmable light
- UL & DLC 5.1 certified and approved
2. Ledmo 200W LED Parking Lot Lights
After installing the Ledmo LED parking lot light on a round pole, one would receive up to 5000k Daylight White light. In addition, the easy-to-install waterproof lamp can produce light with 26,000 lumens, creating a better night atmosphere. The hollow-out heat sink design makes the lampâs weight lighter and has better heat dissipation.
Apart from these functions, the adjustable lights can be positioned in different directions. This photocell-driven LED parking lot light can efficiently work under extreme temperatures, and the life expectancy of the LED is about 50000 hours.
- Â ETL & DLC listed
- Photocell enabled
- 5-year warranty
- Non-dimmable
- Requires an additional adaptor to transform the slip fitter into arm mounting.
3. LEONLITE 300W LED Parking Lot LightÂ
The fabulous 300W Leonlite LED parking lot light with photocell renders 42,000lm of ultra-bright light. A good substitute for the traditional 1500W halogen lamp, it comes coupled with both dusk-to-dawn mode and manual dimming, and you have the option of switching the mode with an uncomplicated change of the cap on the top.
Owing to the built-in 6000V surge protector, they are very safe to use. Thus, this light is suitable for use in parking lots, driveways, and sports fields. This industrial parking lot light is UL listed for high quality.
- Dusk to dawn detector & manual control
- UL listed
- No DLC certification
4. RuggedGrad 150-Watt LED NextGen II LED Parking Lot Light
RuggedGrad Parking Lot Light uses the new 3030 LED modules that produce up to 140 Lumens per watt, helping save even more by using a lower watt unit and still getting the light you need. This LED area light only uses Premium grade LED components and high strength housing, making this an industrial grade LED Parking lot or Shoebox light.
The bright 150-watt LED delivers 20,000 Lumens and can replace a 400 or 500-watt Metal halide MH or HPS/HID light. The 5000K light color ensures a clear, luminous light. The light may be used as Parking Lot Lights, Sports Court Lights, Street Lights, and on walkways, roadways, or other similar areas. The Premium Meanwell HLG Driver is 0-10V dimmable. The light comes accompanied by a fixed arm mount to secure them to lighting poles or walls.
- UL Listed and DLC 4.3 Premium certified
- 140 Lumens per watt
- No dusk-to-dawn feature
5. Lightpolesplus 120w LED, 12" Shoebox Light Fixture
This Lightpolesplus light fixture, engineered and manufactured in Wisconsin, USA, utilizes domestic and imported components. Having earned an ETL certification, the lights confirm to UL STD 1598 & CSA STD C22.2 # 250.0 for humid locations. The 0-10v dimming standards of the drivers are meant for light control. The company provides high-output Chip-On-Board (COB) LEDs in 5000K, 4000K, and 3000K options and other custom color temps upon request.
Standard photometric distributions include Type V Round, Type V Square, Type IV FWD, Type III Wide, Type II Wide, 70° Medium Spot, and 30° Narrow Spot. In addition, custom distribution types are also available upon request.
- High-quality guarantee
- Open to customization
- The prices are higher than the competing industry average
- Photocells are not included
6. HYPERLITE LED Parking Lot Light 200W
The 150-watt Hyperlite LED parking lot light comes coupled with a maximum lifespan of 50000-hours. The floodlight also consists of a photocell sensor. Therefore, you do not have to control the illumination manually. Moreover, the shoebox LED light has a hollow design, so this lighting fixture offers faster heat dissipation. Since the adjustable pole mount has a 180-degree rotating arm, the angles of the light may be adjusted accordingly.
Likewise, these power-saving lights are suitable for parking lots, driveways, and other similar outdoor locations. The shorting cap allows easy replacement of the photocell sensor. This light works with most square poles.
- UL/DLC Certification
- Easy Single Installation
- Actively costly
7. AntLux 150W LED Parking Lot Lights
AntLux is a highly recognized manufacturer of light fixtures. Once you install the 150W LED parking lot lights from AntLux, surrounding areas will be well lit with over 18,600 lumens. The 5000k LED bulb delivers a bright white light that offers clear visibility. As a result of using only 150 watts of power, the energy bill would reduce as well.
Furthermore, the included photocell assures that the lights turn on at dusk and switch off at sunrise. The LED parking lot lights are easily installable and are not at all time-consuming.
- IP66 waterproof
- Photocell included
- Not UL and DCL certified
- The angle of the brackets is not adjustable
8. Hykolity LED Parking-100W Lot Light with Photocell
Hykolity is another popular Shoebox light brand. People will consider Hykolity if they want to replace their 500-600W HID/HPS.
This 100W LED parking lot light with photoelectric sensors uses high-efficiency chips to contribute 150lm/w bright light, keeping your parking lot, driveway, sports field, and backyard well illuminated, and you can save hundreds of dollars a year in the process. The type3 distribution provides more comprehensive lighting coverage, and as a result of being equipped with a trunnion U-shaped bracket, it can be easily installed by a single person. The installation process only involves two steps, where first the U-shaped bracket is placed on the wall, followed by the screws being tightened and secured to the wall.
- UL & DLC Certified & Easy to attain rebates
- Only 15,000 Lm, hence not suitable for large venue lighting
- The wire may not be long enough
9. EverWatt 300W LED Outdoor Parking Lot Light
Now you can experience tremendous savings using just one-fourth of your current power usage without compromising on brightness. Equivalent to the 1000W metal halide lamp, the 5000K bright white LED light merely utilizes 300 watts of power.
Above all, this is possible due to the highly efficient LED chips that can provide over 20000 lumens.
- UL and DLC Premium listed
- Produces energy-efficient 140 LM/W
- Slip fit mount or arm mount
- Screws may not be long enough.
10. Kadision 150W LED Parking Lot Light with Photocell
The Kadision LED light belonging to the parking lot series has been upgraded recently to a newer model, enabling higher lumens of 130lm per watt. It offers an output of about 19500 lumens which can operate well in any parking lot and substitute a 500W MH or HPS/HID. Once the replacement is done, these pole lights can dramatically lower energy bills. Further, this fixture may operate either with or without the photocell sensor.
Most importantly, the LED Shoebox lightâs smooth dimming feature from 20-100% with modern LED dimmers allows you to control the look and mood of your space. It protects against input surge, output over-voltage, short-circuits, and over-temperature to ensure trouble-free operation. Installation problems have been plaguing a vast number of customers.
- ETL Listed
- Dimmable lights & Photocell enabled
- Cannot adjust the angle of the bracket
- Slightly expensive
To conclude, investing in superior quality parking lot illuminants for streets, parking lots, and all other wide-open spaces needing a high volume of light will provide the required illumination you need in any environment.
Thanks for stopping by and going through our review of the best parking lot lights available in 2021. We hope our reviews will help you make the right choice in selecting a lighting solution that meets your requirements and gives you an idea about its features, benefits, and handicaps.
