Best LED Tube Light for Workshops
LED tube lights are suited for various commercial and industrial lighting situations. Be it an workshop in which lively discussions are had or an industrial workshop in operation, LED tube lights have served their purpose of illumination, bringing about greater convenience to people.
In the past, workshops would have traditional fluorescent lights installed on the ceiling to meet lighting needs, and the cost was relatively low. With the development of LED lights, these have become more and more commonly used to replace traditional fluorescent lights in industrial and commercial settings as well as home lighting. If you are looking for a light suited for replacing traditional fluorescent lights with in workshops, the LED tube light is a very good choice.
Part 1. Why Choose LED Tube Lights for Workshops
Part 2. Recommend the Best LED Tube Light for Workshop
1. Energy saving: The energy saving attribute is one of the biggest advantages of LED lights compared to traditional fluorescent lights. Taking the Lepro 17W T8 4ft LED Tube Light as an example, this can be used to replace a 32W fluorescent tube; with an output of 129 lm/W, it can save energy by 47%.
2. Long service life: The LED tube light has a service life of up to 50,000 hours, which is 13 times longer than that of fluorescent tubes. It not only saves the cost of making multiple purchases of tubes, but also saves the cost of replacing tubes.
3. Environmental protection and safety: The LED tube light, as a form of green illumination, will not produce any harmful substances that pollute the environment.
4. Quiet and soft: The LED tube light will not produce noises such as buzzing, and will not cause any interference when used in a quiet workspace. The light emitted is relatively soft and does not flicker, thus also protecting the eyes.
The above introduces some of the advantages of the LED tube light compared to traditional fluorescent lights. If there are any disadvantages, it will be that the unit price of the LED tube light is more expensive, but from the perspective of the long-term cost of replacing lights, the LED tube light is more cost-effective. Below, the Lepro LED Tube Light will be introduced as reference.
The Lepro brand currently carries various models of T8 4ft LED tube lights, such as the Type B single ended power LED tube light, and the ballast bypass double ended power LED tube light, etc., with an output of 2,200 lumens and color temperature of 5,000 K (daylight white). So, why are Lepro LED tube lights said to be the most suitable for workshop lighting?
First of all, it has UL certification and safety guarantee, so using it in workshops with people or valuable equipment does not pose any safety hazard.
Secondly, with DLC4.4 certification, customers can receive a certain amount of energy subsidy and save cost when purchasing Lepro LED tube lights.
Thirdly, the luminous efficacy is high. The 17W Lepro LED tube light has an output of 2,200 lumens and up to 129 lm/W, which can save more electricity.
Finally, Lepro provides a five-year warranty, so there is no need to worry about any problems that may arise during use.
In addition, it is necessary to note that different LED tube lights have different installation methods, and it is necessary to confirm before use.
Type A LED tube lights are plug and play lights, and the cost will be higher. Before purchasing and using, it is necessary to confirm whether the LED tube light has good compatibility with the rectifier.
For Type B LED tube lights, the rectifier must first be removed, and the installation of single ended power and double ended power is also different. Check the video below for the detailed steps to install LED tube lights.
