Does the Winter Season Affect How Solar Light Works
Solar lights will still work in the winter, so long as there is plenty of sunlight to charge the devices. LED Solar lights are quite beneficial in any season, including winter. It doesn’t matter if it’s snowing or icing; as long as the lights can plenty of sun to completely charge, they will work when you need them to.
Buying, installing and maintaining outdoor solar lamps is effortless, even when it’s winter. Best of all, there is little maintenance that needs to be done on your solar lights once you’ve installed them, no matter where you live.
How Effective are Solar Lights in the Winter
LED solar security lights will work just as well in the winter as they do in the summer so long as they receive another sunlight to give the batteries power to start working. Many people wonder if these lights will even work when it’s been snowing or icing in the winter. Absolutely! Manufacturers have designed these lights to ensure that they can withstand an array of weather conditions such as snow, ice, wind, heavy rain, etc.
Solar lights were created to work 365 days a year through the absorption of solar energy from the sun. They can work up to eight hours, which means more than enough protection for your home.
How to Ensure Your Lights Work on Non-Sunny Days
If you live in a region that gets a lot of snow, you can rest assured that your solar lamp post will work. You just need to do some quick maintenance on the device to ensure it can soak in the solar rays. If the panel has accumulated ice, snow or other debris, use a dry towel to remove it. Never use cleaning chemicals on it.
If the day is cloudy (without much sun), the amount of sunlight the device gets will be heavily reduced. If you want an all-night light, the device must have at least four hours of sunlight.
Does Where You Place the Solar Panels Affect the Lights During Winter?
The position of the noontime sun changes in the summer and winter because of the Earth’s rotation. The change may be minor but can affect how effectively the solar panels absorb the sunlight based on their installation. If the solar panel doesn’t get plenty of direct sunlight, it’s not going to work as well. If you see the amount of light it gets decrease, you’ll need to move the panel to another area that does receive more light.
Another option is the LED solar floodlights with separate panels, which are connected by a 5m cable. This allows you to put the solar panel in a better place, so it gets as much sunlight as possible.
How to Properly Store Your Solar Lights
If you stop using solar panels, you need to store them properly. What do you do?
  • Switch the light to "off"
  • Take apart the light
  • Remove the batteries (if you’ll be storing them for longer than a few days)
  • Use bubble wrap or spare cloth to wrap the solar lamp (this keeps it from cracking or breaking)
  • Store in a dry location such as a utility shed, basement or garage
When you’re ready to use them again, use a dry cloth (no chemicals) to remove any dust that has collected, reassemble and install.
