Garage Lighting Ideas – How to Choose the LED Garage Lights
Discover the most frequently and widely used interior garage lighting options to brighten up what would otherwise be a dull, dreary, and depressing interior. Your garage must have sound and ample lighting, whether you use it for storage purposes or as a workshop.
Why Choose LED Garage Lights?
LED luminaires only use about half the wattage of their fluorescent tube counterparts and as much as 90% less than a traditional incandescent bulb. This implies that if you use the LED options, you get more illumination, employ less electricity, and save thousands in the long run. Without a doubt, LED lighting is more energy-efficient than its outdated rivals and can also last almost twice as long as fluorescent tube lights, saving you both money and hassle since you would not have to replace them as often.
Types of LED Garage Lights
High Bay Lights
High bay lights are an ideal choice for garages with high ceilings, usually over 15 feet in height. They can be suspended from the ceiling with the assistance of a hook, pendant, or chain or may be mounted directly to the ceiling. You may choose from among different wattages depending on the height of your garage ceilings.
Power | Equivalent | Mounting Height | Coverage |
Lepro 100W High Bay Light | 250W HID | 12-18ft | Dia 40ft |
Lepro 150W High Bay Light | 400W HID | 14-22ft | Dia 46ft |
Lepro 240W High Bay Light | 1000W HID | 19-28ft | Dia 52ft |
LED Shop Lights
Shop lights possess a tube-like shape and may be hung from the ceiling with a chain or rope or mounted directly to the ceiling. They typically come with a cord for plugging directly into a wall outlet, preventing you from having to figure out how to hardwire the lights to your electrical system.
LED Tube Garage Lighting Fixtures
These lights are either single or double tube fixtures. The tubes are the actual bulbs of the fixture, which are meant to offer the most direct radiant light where you most need it.
Depending on the fixture you choose, some of them may be mounted flush to the ceiling or suspended so they can hang lower, while some others have the option to be installed either way.
LED Wraparound Lights
Wraparound lights are in the shape of a semicircle. The flat side sits flush against the ceiling, while the circular side hangs from the ceiling, dispensing the light in various directions.
Flush-Mount Ceiling Lights
Flush mount lighting is a common ceiling light that may be installed throughout your home, even in small spaces with low ceilings. They have a circular shape and are usually meant for decorative purposes, making them the perfect choice for other common areas around your home, such as hallways, patios, and offices.
Figure Out How Many Lumens Your Garage Needs
The number of lumens your garage needs depends on the size of the space you are looking to illuminate, the natural light conditions in the garage, and the type of lighting fixtures you adopt. Light output is measured and listed in lumens, and, in general, you would need 50 lumens per square foot for ambient lighting, 300 lumens per square foot for task lighting, and 75 lumens per square foot for accent lighting.
After determining the amount of light required, choose light bulbs with enough energy to deliver that luminosity. For example, let’s say you have a 360-square-foot two-door garage, and you want to install ambient lighting in one half of the space and task lighting in the other half.
As per the guidelines above, you would need 54,000 lumens on the task side and 9,000 lumens on the ambient side. Using a lumen-to-watt conversion chart, you can effortlessly decide upon the type of light you need, the number of illuminants necessary to brighten the space, and the wattage you want for your bulbs.
For example, 38-watt LED bulbs produce 3,000 lumens each. Hence, you would need three of those on the ambient side or three 200-watt incandescent bulbs to generate that same amount of light.
