Best LED High Bay Lights for Factory
Why Choose LED High Bay Lights in Factories?
There are many types of industrial illumination lights on the market, such as traditional fluorescent lights, metal halide lamps, LED high bay lights, LED shop lights, LED tube lights, and so on. So then why should we choose LED high bay lights as factory illumination lights?
First of all, factories generally have larger space, and so it is difficult for ordinary lights to satisfy the illumination demands. As the name implies, LED high bay lights are applied to the illumination of spaces with higher ceilings, emitting light at high efficiency, capable of outputting a higher light quantity.
Second of all, factories’ environmental conditions vary. LED high bay lights are made of firm materials, can sustain protracted use, and are convenient to install. They can work as normal even in adverse environments. Moreover, they have long service life and can even lower light switching costs.
Once again, LED high bay lights are highly secure. On the one hand, they will not produce matter that is harmful to the environment; on the other hand, LED high bay lights dissipate heat well. It is quite suitable for factories to use LED high bay illumination out of consideration for safety.
Overall, if you are looking for lights that are well-suited to illuminating factories, then LED high bay lights are a very good choice. Next we will present the 5 most popular LED high bay lighting fixtures for factories.
Top 5 LED High Bay Lights for Factories
1. Lepro LED High Bay Lights
Lepro LED high bay definitely is the model that has the highest price-performance ratio as factory illumination lights. It has obtained UL safety certification, has a 5-year warranty period, and is safe and secure to use. At the same time, it is also extremely competitive in terms of price. The 100W UFO LED high bay lights output a brightness of 13,000lm and have a sale price of $79.90. Also, if you have the chance, you can obtain a DLC energy subsidy. It has attained excellent quality at a reasonable price under the premise of guaranteeing quality. In addition, the Lepro brand also offers multiple models to choose from: based on your needs, you can choose 100W, 150W, or 240W UFO high bay lights.
Lepro UFO LED high bay lights are also quite convenient and simple to install. The video below presents the installation method in detail, which you can check out to find out the details.
2. Hykolity LED High Bay Light
Hykolity likewise offers several power options. The 100W UFO LED high bay light is equivalent to 250W HID, and the 150W LED high bay is equivalent to 400W HID, which can help factories economize quite a lot on electricity costs. Apart from this, Hykolity UFO high bay is composed of industrial-grade heavy-duty die-cast aluminum housing, dissipates heat well, and can sustain protracted use. The product comes with a hook, which is extremely convenient when installing, suitable for use in factory illumination.
3. HYPERLITE LED UFO High Bay Lights
As factory illumination lights, HYPERLITE LED UFO High Bay Lights are slightly more expensive than the above-mentioned 2 product models, but they are highly efficient at emitting light. The 100W LED high bay lights output 14,000lm brightness, reaching as high as 140lm/w. This model of UFO high bay also comes with a hook, which is convenient for installation. At the same time, it has a 5-year warranty to ensure safe use.
4. Sunco Lighting 2 Pack UFO LED High Bay
Sunco offers 150W and 240W power options. The 150 UFO LED high bay lights output 21,000lm brightness, equivalent to 600W HID; the 240W LED high bay lights output 33,500lm brightness, equivalent to 1000W HID. It is noteworthy that Sunco has passed UL safety certification and offers a 10-year warranty, which is significantly reassuring as far as factories are concerned.
5. JOMITOP UFO High Bay Lights
JOMITOP offers a selection of lights of 3 different powers for factory illumination. The 100W ones output 15,000lm brightness, equivalent to 400W HID; the 150W ones output 22,500lm brightness, equivalent to 600W HID; and the 200W ones output 30,000lm brightness, equivalent to 800W HID. For the sake of comparison, JOMITOP LED high bay lights are highly efficient at emitting light and have high brightness, so they can completely satisfy factories’ illumination demands. They are simple and convenient to install and have a 5-year warranty, so they are also a great choice for factory illumination.
How Many LED High Bay Lights Do I Need for My Factory?
Overall, this pertains to the size of the factory space, such as the length, width, and height, as well as the specific model of LED high bay lights used. As for Lepro LED high bay lights, if they are used to illuminate the interior of a factory, then it is recommended to install the 100W Lepro UFO LED high bay lights at a height of 12-18ft, it is recommended to install the 150W UFO LED High Bay lights at a height of 14-22ft, and it is recommended to install the 240W UFO LED High Bay lights at a height of 19-28ft. The ranges covered by the different LED high bay lights installed at different heights also differ. If you would like to calculate precisely, we suggest that you adopt professional illumination design software such as DIALux or AGI32 to make calculations.
